spring pads
Old 07-17-2008, 08:54 AM
ryan48's Avatar
Default spring pads
eibach mentions ride heigh adjustments can be made via the spring pads....how tall are these, and can you simply cut them down?
Old 07-17-2008, 11:52 AM
Default Re: spring pads
Hi Ryan48,
When I installed my shocks and springs I took down the part # off the rear spring pads (forgot to do so for the front). Anyway, I compared the part # with those posted on performance products (formerly automotion) for a 320slk. The #'s matched, I had the 5mm spring pads. 5mm is the thinnest pad offered. You might be able to shave a little, but at just 5mm if you shaved it I think the spring might cut through over time. Sorry I can't help with more info about the front spring pads.
Old 07-17-2008, 01:05 PM
BrianBrave's Avatar
<--- Huge Horsepower
I used the search function and entered "spring pad" (the title of your thread) and look what popped up!
https://www.crossfireforum.org/forum...ght=spring+pad
Check out post #7
chturner
19
10-14-2019 04:42 PM
2005 Ragtop
10-03-2015 03:01 PM
ritous1
09-26-2015 01:27 PM
ayebb
09-18-2015 03:35 PM
Valk
09-17-2015 11:43 AM
Quick Reply: spring pads
