Ordering new rims, need advice asap
Old Aug 17, 2008 | 06:14 PM
bhays's Avatar
Default Ordering new rims, need advice asap
I am ordering a set of ADR Decadence rims for my roadster.
They are 18x8.5 and 19x9.5. The seller (Elites-Wholesale.com) says I won't need spacers, but that doesn't sound right with what I've read here on the forum. Will I need 20mm spacers in the rear to make the front and back line up with the wheel well the same?
Thanks for any advice.
Old Aug 17, 2008 | 07:09 PM
Voyager's Avatar
Default Re: Ordering new rims, need advice asap
im terrible at understanding rims but i think it depends on the offset not necessarily the size of the rim.
Old Aug 18, 2008 | 04:31 AM
maxcichon's Avatar
The ADR wheels, made by Golden Apple Corp. have a 66.56 mm bore for the 5X112 model. You will not need spacers for the hub fit, but, if the offset matches are not close enough you will.
Please use this tool:
http://www.rims-n-tires.com/rt_specs.jsp
and check the clearances before you need to.
Old Aug 18, 2008 | 06:01 AM
amick6534's Avatar
I think that those rims will look good on your car Brett.
Old Aug 18, 2008 | 06:22 AM
mrphotoman's Avatar
what is the offset you are going with?
Old Aug 18, 2008 | 07:03 AM
bhays's Avatar
Yeah, I looked around for quite a while. I got the black centers with chrome lip and center cap. I think it should look pretty good too. Thanks.
I went ahead and had them send 15mm spacers for the rear, I can decide to use them or not.
Old Aug 18, 2008 | 07:04 AM
bhays's Avatar
Front is:
18 x 8.5 ET 20
Rear is:
19x9.5 ET 25
The link said the front will stick out 15mm farther so I went ahead and got 15mm spacers for the rear.
Old Aug 18, 2008 | 07:27 AM
maxcichon's Avatar
Front is:
18 x 8.5 ET 20
Rear is:
19x9.5 ET 25
That should look really nice!
Did you go through this Sticky? Some good stuff...
https://www.crossfireforum.org/forum...ad.php?t=25349
Old Aug 18, 2008 | 06:12 PM
NoCones's Avatar
Front is:
18 x 8.5 ET 20
Rear is:
19x9.5 ET 25
They'll actually stick out slightly more than that. 15mm of offset plus another 1/2" from the 1" width increase.
Old Aug 18, 2008 | 06:22 PM
grt place to shop, they will look very good...looking @ ADRs as well...M Sport...blk ctrs..let us know how it turns out...
TerryR
Dec 13, 2019 03:27 PM
Steven 4190
Nov 25, 2015 10:12 AM
o55ie18
Oct 5, 2015 05:50 PM
Billto
Sep 28, 2015 12:05 PM
Sep 25, 2015 02:16 AM
