Tire Size Help
Old 09-24-2008, 11:15 AM
amcordo's Avatar
Default Tire Size Help
Hello everyone,
I've read through the 18" all around threads but I desperately need one question answered: how important is keeping the rear tire .9" larger? How much play do I have?
I want to put a 245 40 18 on the rear and a 235 35 18 on the front.
245/40/18 has a diameter of: 25.7" (OEM is 26")
235/35/18 has a diameter of: 24.4" (OEM is 25.1")
Will this work (not mess with ABS or traction control), or am I too far off?
Anthony
Old 09-24-2008, 11:32 AM
maxcichon's Avatar
Default Re: Tire Size Help
Please use this tool:
http://www.rims-n-tires.com/rt_specs.jsp
Please?
Old 09-24-2008, 11:36 AM
amcordo's Avatar
Please?
Thanks, but I did use that tool. It doesn't answer the question of whether the tractional control in our cars is going to go nuts from having a difference in the diameter of the front and rear tires by more or less than .9".
Old 09-24-2008, 12:11 PM
maxcichon's Avatar
Originally Posted by amcordo
Hello everyone,
Anthony
Ok, sorry!
That would be a radial difference of .150" rear and ..350" front.
I'm not sure if the difference (deviation from OEM) beween front and rear would cause problems for traction control or ABS.
Old 09-24-2008, 12:24 PM
Oh that lil thing says I'm 1% faster cause I moved the rears from 255's to 245/35/19's. I knew I was born with an intrensic knowledge of speed!!!! I even do it on accident.
Old 09-24-2008, 01:00 PM
amcordo's Avatar
Ok, sorry!
Thanks anyway, I've been pouring over search results in the forum and I was surprised that I couldn't find anything addressing this. Usually if you sift through results long enough the answer is in there somewhere...
Old 09-24-2008, 01:04 PM
If it helps any I've seen lots of combination of tire & wheel sizes posted here and never seen someone say they were having problems with the ABS or TC because of it.
Old 09-26-2008, 01:39 PM
check this site out for tire fitment info. its a free site with alot of useful tools for plus sizing and wheel fitment data.
www.sizeitup.com
BrenLW
08-05-2015 04:53 AM
onehundred80
08-02-2015 11:37 AM
onehundred80
Canada
07-24-2015 03:50 PM
crymar
07-17-2015 08:46 AM
syfi
07-12-2015 05:59 PM
Quick Reply: Tire Size Help
