camber kit question also 20 inch 19 inch combo
Old Oct 20, 2008 | 07:34 PM
srt-6novice's Avatar
Default camber kit question also 20 inch 19 inch combo
looking for some info on anyone getting camber kits for the srt-6. I saw a few on ebay but pretty pricey. i was first considering getting the eibach pro kit with konis while running 19 inch rears and 18 in fronts. right now i have stock suspension and i have 20's in the rear and 19's in the front. i like the look of the 20/19 combo, but my rear wheels are showing some condiderable wear. i am afraid that if i was to lower it i might have to use a camber kit since my camber is already bad not being lowered and just having bigger wheels. please let me know from anyone what they are running and how it works for them. I AM LOOKING TO GET INFO ON ALL THE SUBJECTS ABOVE. i REALLY NEED HELP. THANKS.
Old Oct 21, 2008 | 04:02 PM
Fritzauf's Avatar
Default Re: camber kit question also 20 inch 19 inch combo
If you're having a problem with uneven tire wear due to negative camber you will most likely need to install the Camber Adjusting Bolt kit. Check your shocks also. Your Chrysler dealer can get the proper Camber Bolt kit reasonably priced and install it also.
deerhunter
Jan 16, 2021 10:56 AM
ayebb
Sep 18, 2015 03:35 PM
jaesa
Sep 7, 2015 01:50 PM
davidc90
Sep 6, 2015 10:37 PM
RedNeck
Sep 4, 2015 09:54 PM
