Falkens, how about these?
Old Jan 14, 2009 | 10:00 PM
cgocifer's Avatar
Default Falkens, how about these?
Had good experiences with Falken tires before. What do you think about these sizes?
275/35/19 Rear
225/45/18 Front
I know I'd be increasing the sidewall height a little, but that may improve the comfort of the ride a bit. What do you think this would look like? Have any of you done this to the front? Pictures?
Old Jan 15, 2009 | 12:22 AM
Mimi05SRT6's Avatar
Default Re: Falkens, how about these?
This has been brought up several times on here. Your speedo will be slightly off I would imagine being it's a taller tire. So beware that you'll be going faster than what your speedo indicates. l
Old Jan 15, 2009 | 03:49 AM
Erzer's Avatar
In this sizing instance, it actually looks like you will be driving at a slower speed than indicated on the speedometer.
I've been using 1010tires.com to consider different alternatives, close to deciding on sizes, and did a quick comparison of yours to the stock sizes. On the front it gave this warning since you are at 3.43% of change in diameter.
Warning! When changing tire sizes, we recommend staying within 3% of the diameter of the original tire. Any more than this and you face the risk of brake failure
Old Jan 15, 2009 | 03:50 AM
Beaner's Avatar
I think it would look fine. And for the speedo changes I think it is minimal.
Tire 1 Tire 2
Tire size 225/40-18 225/45-18
Section width 225 mm (8.9'') 225 mm (8.9'')
Sidewall 90 mm (3.5'') 101 mm (4'')
Tire diameter 637 mm (25.1'') 659 mm (25.9'')
22 mm (3.5%) taller.
Circumference 2000 mm (78.7'') 2069 mm (81.5'')
Revs per mile 804.6 777.7
When speedometer reads 60mph (96.6km/h) actual speed will be 62.1mph (100km/h): 3.5% faster.
Old Jan 15, 2009 | 06:12 AM
maxcichon's Avatar
I like my FK452's. I went 19 and 20 with a wider tread (235 and 275). Very happy!
Old Jan 15, 2009 | 04:38 PM
billangiep's Avatar
Maxcichon,
How many mile's on the new Falkens and are you comparing them with the Continentals? Also are they a directional tread (able to rotate side to side)?
Thanks
Bill,
Old Jan 15, 2009 | 05:02 PM
maxcichon's Avatar
Originally Posted by billangiep
Maxcichon,
Thanks
Bill,
Bill,
5,000 miles and yes I'm comparing them to the SportContact 2's it came with. However, I didn't own it from new. I bought it with 10,000 miles on the clock and the rears looked very good at that time. I drive pretty fast in straight lines, but don't beat it up very much around twisties (except at the Dragon! ) and was amazed at how much they had worn after 15,500. It came to light when we were returning from last fall's Tail of the Dragon (Tina was driving) and with DAMP roads the ESP was kicking in. When we arrived at he house, I looked closely and had ~ 2 mm (.040") of tread above the wear bars. I thought this was pretty poor for wear so started looking for UHP tires with:
  1. Better wet performance, and,
  2. Higher UTGC (?) rating for wear.
The BMW and Audi forums liked these for the:
  1. Good wet performance, and,
  2. Improved ride.
The higher wear rating was just a bonus.
And yes, they are directional. Just make sure you take as many right turns as left!
Good hunting, Max
Old Jan 15, 2009 | 05:26 PM
billangiep's Avatar
Max thanks for the report. I was sold on these until finding out there directional. Not really wanting to loose the ability to rotate. Decisions....
Old Jan 15, 2009 | 05:55 PM
maxcichon's Avatar
I forgot to mention:
I really like them? In my humble opinion (!?), side to side rotation should be needed only if there is a problem, mechanically. But, as usual, I may be wrong.
Go figure-I'm an optimist!
Diabloflash
Canada
Sep 26, 2014 05:51 AM
chilj
U.K.
Jul 1, 2012 02:17 PM
MK INDY
U.K.
May 13, 2011 02:43 PM
Cody M
Apr 11, 2011 03:17 PM
mrphotoman
Jul 5, 2009 03:37 PM
