'08 audi s5 rims on crossfire
Old May 10, 2009 | 02:03 PM
welder7018's Avatar
Default '08 audi s5 rims on crossfire
So, what do you guys think ...they look good and i can get them 19 and 20's thanks eric
Old May 10, 2009 | 02:35 PM
Default Re: 08 audi s5 rims on crossfire
I think they will look nice on the Crossfire...
Old May 10, 2009 | 06:07 PM
welder7018's Avatar
yeah thats what i was thinking ...i kinda wanted to stay with the factory style look...like these are the rims it should of came with mabye... here are the offsets and what not could you telll me if theyll fit thanks
SizeBolt PatternETStock LevelAdditional InformationPrice19x8.505x112+38In transit $29519x8.505x112+25In stock $29520x9.005x112+25In stock $385
anything else i should be worried about
Old May 12, 2009 | 11:00 AM
welder7018's Avatar
Default Re: '08 audi s5 rims on crossfire
they just told me that they dont know if they would fit...they might they said.....whats the stock fitment for the front and back rims...thanks eric
Old May 12, 2009 | 11:06 AM
they look like they will fit,
the stock wheels with no lip is front offset 35 rear 20 the new rims look like there is no lip,, the fronts will stick out 3 mm and the rear will be in 5mm
1 millimeter = 0.0393700787 inches jim
Old May 12, 2009 | 11:18 AM
welder7018's Avatar
will that look like ***?
Old May 12, 2009 | 11:30 AM
I think they will look very nice if that's all they will stick out. I have 12mm spacers in the rear, and 10mm in front with the OEM wheels. There's quite a few folks here with spacers. I think it makes the car look better.
Old May 12, 2009 | 11:38 AM
welder7018's Avatar
it sucks i cant test fit them before i get them
Old May 12, 2009 | 11:46 AM
They are the same bolt pattern. Why do you think they won't fit?
Old May 12, 2009 | 11:52 AM
welder7018's Avatar
my luck sucks with this type of crap...i thought the hub hole had to be right or something like that
LantanaTX's Avatar
Same bolt pattern and 10mm spaces in the rear and you will be fine! They look great! If the stock wheels had an evil twin these would be them...
Old May 12, 2009 | 11:54 AM
LantanaTX's Avatar
Might be a good idea to check this out but there are inserts to cure this as well and many aftermarket wheels have to use them
Old May 12, 2009 | 01:44 PM
former NXMX5's Avatar
the S5 has the same size wheels all around... whered you find the staggered fit? or are these replicas?
Old May 12, 2009 | 08:45 PM
welder7018's Avatar
Hartmann Performance Wheels - Audi wheels, stock replicas ....this is were i found them ...im gonna get one and see how it fits up for now
Old May 12, 2009 | 08:52 PM
welder7018's Avatar
also they seem to be out of 19x 8 fronts with 38et..but they have fronts with 25et...could i just get spacers for the front and grab them thanks eric
Old May 14, 2009 | 03:55 PM
Yes you could, but as someone running spacers, if they would have made the wheel with an offset and backspace that would have allowed me to NOT use spacers, I would have most definately used those.
Not that spacers are bad, but they put undue strain on suspension pieces, even if it is only a few mm, I would wait and get the ones that are more spec appropriate, just my .02
Old May 14, 2009 | 08:58 PM
thomatt12's Avatar
Those wheels really look nice. It's perfect for the Crossfire.
_______________________
familytram
15
Apr 15, 2008 06:50 AM
Maxwell
Other Cars Etc
Jul 16, 2007 09:38 AM
jimxty
Jul 3, 2007 03:10 AM
slide93
Jan 19, 2005 07:23 PM
inesshell
Feb 22, 2004 12:41 PM
