Parking Brake Adjustment/Replacement
Old Jul 16, 2009 | 10:45 AM
Default Parking Brake Adjustment/Replacement
My parking brake is not nearly as tight as it should/could be and I do not know if the previous owner accidently tried starting to move the car with it on once or twice or what . I know on certain cars there is an adjustment somewhere. Can anyone shed a little more light on this somewhere or where it might be located?? Also, if I am correct, the parking brake is simply a drum brake? And if so, is there a replacement shoe or pad part #??
Thanks guys.
John
Old Jul 16, 2009 | 06:40 PM
kingkub57's Avatar
Default Re: Parking Brake Adjustment/Replacement
yes there are two different area's that can be adjusted, one is the tensioner at the parking brake lever, and then your star wheel adjustment screw's in the rear, and yes these are replaceable parts
Old Jul 17, 2009 | 09:11 AM
Thank you, I have searched around and found very little info on the subject for these cars. Maybe because of the age of the car and limited miles most people drive their XFs, not many have had to replace these parts....
Old Jul 20, 2009 | 09:27 AM
Come on guys, nothing???
Old Jul 20, 2009 | 12:30 PM
Stogey's Avatar
Because it is a parking brake, not many folks have ever changed these shoes out and you are correct they are drum style brake shoe.
Old Jul 20, 2009 | 01:26 PM
Thanks guys.
John
Download the Shop Manual (.pdf file) and store on your computer for future reference.
Go to section 5, page 57 which explains the required method of adjustment.
The manual can be found here; http://www.majormotorshotrods.com/_d...ice_Manual.pdf
It is also found as a sticky under the SRT6 section and is in the documentation thread.
Old Jul 20, 2009 | 03:08 PM
180, you are a good guy, maybe this time my dumba$$ will download it and keep it.
Thanks.
Old Sep 18, 2009 | 02:10 PM
Black_X_Fire_04's Avatar
Thanks for the pdf Ive been looking for something and im in the process of my brakes now and i needed to figure out how to release the tension of the brake so i can remove the rotor easier.
Old Sep 18, 2009 | 03:44 PM
OKC-XFR's Avatar
If anyone is interested in what the parking brake looks like, I took a picture when I was changing out my rotors:
Old Sep 27, 2009 | 02:49 PM
markr6754's Avatar
Thanks a lot. The proverb is proved again "A picture is worth a thousand words."
Old Sep 27, 2009 | 04:49 PM
32krazy!'s Avatar
if you look closley at that foto the star cannot be adjusted with the rotor on like conventional cars. you make an adj. theinstall the rotor and spin then readjust. its a pain to do as you have to remove the caliper to do any adjustments
Old Sep 27, 2009 | 05:47 PM
Not true actually you can adjust the hand brake without removing the rotor etc.
The adjustment of the hand brake is done through a hole for a wheel bolt which has been removed.
See pages 5-59 and 5-60 in the workshop manual available in the SRT-6 Documentation section.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
Mackel
Oct 16, 2015 09:03 AM
Bill F
South Forum
Sep 11, 2015 02:29 PM
