If I buy a Merc spare tire...
Old Aug 17, 2009 | 02:07 AM
Wedge's Avatar
Default If I buy a Merc spare tire...
If I buy a Mercedes spare tire set up, would a 16" or 17" work or should I hold out for something in a 18"?
Old Aug 17, 2009 | 08:13 AM
maxcichon's Avatar
Default Re: If I buy a Merc spare tire..
You might have to do a little investigating-the inside diameter has to clear the calipers AND the outside diameter of the tire must be very close to the size of the tires in the rear, so as to not cause damage to the diff.
Pretty tall order!
Old Aug 19, 2009 | 01:35 PM
Wedge's Avatar
Sounds like I oughta have a chat with my tire guy then
or, maybe just buy a stock sized front that could be used on either end.
Old Aug 19, 2009 | 08:47 PM
Moparrbust's Avatar
You can use a 17'' spare from any 210 or 211 body E-Class or a 219 CLS.............they will definately fit on a Crossfire. Those are what I use to run my skinnies on my 6.
Old Aug 20, 2009 | 12:26 PM
Wedge's Avatar
Thanks Mopar, that's perfect. I'll look into it
Old Aug 20, 2009 | 01:27 PM
Is this something you can run on the rear as well? or will it throw off the diff
Old Aug 20, 2009 | 02:38 PM
SRT SIX's Avatar
Great to have a spare in the "trunk". However it is going to take up most of it if not all. Don't forget you will have to put the original back in there when you change to the spare. Will that fit?
Old Aug 20, 2009 | 02:52 PM
velociabstract's Avatar
It will fit in the back at an angle or the passenger seat. I did a trial run to see if I could get 4 en the car and the most that will fit is 3 with the hatch partially open. And tires are DIRTY!
Les
Old Aug 30, 2009 | 07:48 PM
Wedge's Avatar
Anyone know if that 17" spare will harm the diff?
MiamiTVR
Jan 30, 2016 02:15 PM
crossfireusa
Oct 28, 2015 12:03 AM
rogerlemoine
Oct 26, 2015 12:02 AM
ozkancab
Sep 25, 2015 10:55 AM
Dgiomatch1
Sep 20, 2015 01:05 AM
