Koni Shocks at Tire Rack for $560
Old Feb 13, 2011 | 10:31 AM
LantanaTX's Avatar
Default Koni Shocks at Tire Rack for $560
Best price I have seen.
Old Feb 13, 2011 | 10:53 AM
Beaner's Avatar
Default Re: Koni Shocks at Tire Rack for $560
This is the second lowest price I have ever seen! Very good buy. Thanx for the heads up Lantana
Old Feb 13, 2011 | 02:39 PM
LantanaTX's Avatar
Mine are on the way!
Old Feb 13, 2011 | 04:39 PM
bluecoupe's Avatar
Bob, I thought you were going with Bilsteins?
Old Feb 13, 2011 | 04:52 PM
LantanaTX's Avatar
I was but decided to go Koni after reading everything possible. I would sure like to try the Bilstein but they won't loan them to me. At least with the Koni they are adjustable if I don't like the ride. Hopefuly there will be a setting I like. I saw some shock dynos of the Bilstein and Koni and it looks like the adjustments on the Koni's cover the range of the Bilstein's.
Old Feb 13, 2011 | 05:01 PM
bluecoupe's Avatar
I ordered Koni's too for the 6. If you come across the torque specs, please post!
Old Feb 13, 2011 | 07:16 PM
LantanaTX's Avatar
Torque specs?
Old Feb 13, 2011 | 07:43 PM
bluecoupe's Avatar
Yup, don't the bolts need to be tightened to spec?
Old Feb 13, 2011 | 08:44 PM
Beaner's Avatar
I am guessing you need to read every new package of toilet paper to see just how many squares to use too.
Rear
Install the shock absorber (1) onto the lower control arm then install the bolt and nut (2). Tighten to 55 N·m (41 ft. lbs.) install the top shock absorber mounting hardware (1). Tighten to 18 N·m (13 ft. lbs.).
Front
Install the shock absorber lower bolt and nut (1) to the lower control arm shock. Tighten to 55 N·m (41 ft. lbs.) Install the shock absorber upper mounting nut (1). Tightento 18 N·m (13 ft. lbs.)
2004 Crossfire service manual
2-81 rear suspension
2-82 rear suspension
2-45 front suspension
Old Feb 13, 2011 | 10:51 PM
john book's Avatar
Crap!!!I just paid $600.00. Great price. Thanks for the Torque specs Beaner, mine go on next weekend with spring and brake upgrade. Looking forward to enjoying the improvements
Old Feb 14, 2011 | 06:45 AM
bluecoupe's Avatar
Rear
Front
Toilet paper....................what's that??
Old Feb 14, 2011 | 12:53 PM
Lantana, I was thinking about going to the KYBs you have previously posted on, what is the verdict on those?
Old Feb 14, 2011 | 04:44 PM
LantanaTX's Avatar
the KYB's aren't bad at all. They were a little bouncy for the first few miles and then settled in nicely. With a lowered car they were better than stock. I thought they were fine but still was getting some complaints from my female passengers. I can probably give you a better comparison after comparing them to Koni's which everyone seems to think are the ultimate shock for a Crossfire. I did find out that Koni sells the same shock for the SLK and Crossfire, while Bilstein sells different shocks for each car and the Crossfire version has much stiffer rebound. I would love to know how the Bilstein's perform but I have been the guinea pig more than my fair share of the time (Anza muffler, KYB, V8 conversion, Brembo/MB calipers). I will soon be the guinea pig for a supercharger kit where all the programing is done in the stock ECU with no piggy back tuning system. I was soooo close to buying the Bilstein's, but couldn't figure out if the SLK or Crossfire ones would give me the better ride. I posted asking for help with this decision and didn't get any answers, so I went for the Koni.
Old Feb 15, 2011 | 08:34 AM
Thanks Bob, keep us posted, and thanks for trying stuff out for the rest of us
Old Feb 15, 2011 | 11:25 AM
NeedsWings's Avatar
i will beat tire rack on the koni's, hit me up if your ready
http://www.needswings.com/Koni-Adjus...8041-1229.aspx
Old Feb 15, 2011 | 06:44 PM
bluecoupe's Avatar
Koni Adjustable Yellow Sport shocks Crossfire
Yes you will Rob and thanks very much!
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
