Need Help With What Brakes & Rotors
Old Apr 19, 2011 | 10:06 PM
Erzer's Avatar
Default Re: Need Help With What Brakes & Rotors
Timing is everything. I'm actually considering replacing my brake setup or I should say an upgrade. Though I don't race it or drive as aggressive as some of you, it is my daily driver, except when snow/ice or severe storms like today, and I just want to make sure they are good.
Yes it is an auto stick I drive as close to a stick as I can and want to minimize dust. Also, I will strongly be considering going to 18"s all around; lowering isn't out of the question other than maybe cost.
So with my NA (special edition w/SRT rims) what do your experts recommend? Thanks in advance.
Old Apr 20, 2011 | 06:25 AM
LantanaTX's Avatar
Originally Posted by dtinker
So, I don't need any spacers or different lug bolts, etc. Just swap parts, bleed brakes and drive it.
That is correct for the stock SRT brakes.
Old Apr 20, 2011 | 06:29 AM
LantanaTX's Avatar
You can also run the stock SRT brakes no problem or I would recommend the C32 rotors and MB/Brembo calipers. Paul/Taz with the 55K V8 Crossfire could tell you what size spacer is needed for this set up. I have an extra set of calipers if you want to go this route.
Old Apr 20, 2011 | 04:59 PM
Erzer's Avatar
Thanks, I will get with the other Beast owner...and let you know.
BTW - I really hope the two of you and other V8 conversion owners show up to the CAA in the Rockies this year.
Old Apr 20, 2011 | 05:49 PM
MikeR's Avatar
I had to use a 10mm spacer on the Aero when I put the C32 rotors & calipers on.....stock SRT wheels...
Old Apr 21, 2011 | 07:41 AM
LantanaTX's Avatar
Thanks Mike for the answer. I forgot you had done this also. I think Taz switched to SRT wheels so he could run a smaller 10mm spacer.
Old Apr 21, 2011 | 07:49 AM
velociabstract's Avatar
With the Stoptech's and SRT wheels all you need is a 5 mm, but I put a 10 mm because it was hub centric and the 5's were not. Now I'm using different wheels with no spacers. 30mm offset on the front.
Les
Old Apr 21, 2011 | 08:49 AM
Is the SRT setup identicle to the SLK32 setup?
If so, you will need 4 extra bolts, at least I did (I did this upgrade 2 weeks ago). The mounting points on the rear calipers are nearly twice as thick as OEM and your existing bolts will not work, you will need longer ones, but any auto parts store will have them. Also, we had to modify the dust shields in the front because the calipers would not clear with the mounting points. If you are painting the calipers, please use caution. I did mine in a friends paint booth with a thicker paint formulated for calipers, and after 4 coats, the few millimeters of paint that was on the calipers made the clips stick out just enough to where they were 'clicking' on the back of my OEM wheels. The setup is extremely close to the back of the OEM wheel. All is worked out now, but what a pain I made for myself....
Damn are these brakes insane on a limited, I can only imagine what your feel like Lantana
Old Apr 21, 2011 | 09:05 AM
dtinker's Avatar
My 2006 LTD Roadster will be using STOCK LTD wheels, 2005 stock SRT6 calipers and rotors with Akebono ceramic pads EUR682 on the front. I'm using the stock LTD calipers and rotors on the rear and just replacing the pads with Abebono ceramic pads (don't remember the number), and stock 2006 LTD wheels on the rear as well.
Old Apr 21, 2011 | 06:24 PM
Erzer's Avatar
Sent you a PM.
In the meantime, has anybody used the PowerSlot? I know NeedsWings sells them and they seem very comparable to what TireRack sells them for.
Old Apr 21, 2011 | 06:59 PM
MikeR's Avatar
Erzer, if you get Lantana's calipers that fit the SRT rotors... I have a full set of stock SRT rotors in the garage. You can have them if you pay for shipping.... They have about 25k on them.
Old Apr 22, 2011 | 08:42 AM
Looks like you will not need any additional hardware, but you are more than likely going to have to modify (cut or bend) your dust shields, just trying to give you a heads up...
Old Apr 22, 2011 | 10:43 AM
LantanaTX's Avatar
When usiing the the MB/Brembo four piston calipers, I did not have to modify the dust shields at all. It was a very easy swap. As menetioned, I have two sets of extra four piston calipers. One set for the SRT rotors and one set for the C32 rotor.
Old Apr 22, 2011 | 10:46 AM
Seems a bit funny the 4 piston guys would not need any mod and the 2 piston SLK320 do, odd.
Old Apr 22, 2011 | 11:42 AM
MikeR's Avatar
The C32 rotors/calipers just bolt right up with no changes...at least on the SRT... stock wheels will require a spacer for clearance as mentioned earlier....
Old Apr 22, 2011 | 12:58 PM
dtinker's Avatar
Any idea how much cutting or bending? How thick is the dust shield? Can it be cut with shears or a nibbler, or will I need a plasma cutter? Does anyone have a template of the cut pattern?
Old Apr 22, 2011 | 01:19 PM
With my BBK all I had to do was bend it a little. It's easy to figure out. I think your like me and want all the answers beforehand. Do fret so much, just do it!
Les
Old Apr 25, 2011 | 07:14 AM
  #38 (permalink)
Les
Les is right, just do it, the bend is not that severe, as I decided not to cut mine, but you will definitely need to do something. I read everything I could and called several other well seasoned XF pros and asked them and everyone told me the same thing, bolt up no problems, all same hardware, and I ended up having to go to the store for bolts anyway, so just goes to show you, even when you do think you have done all the homework you can - you can still end up with missing info until you get your hands dirty (just make sure the auto parts stores are still open when you start - I almost had a 2 day brake job because of 4 little bolts LOL)
Old Apr 25, 2011 | 07:20 AM
  #39 (permalink)
dtinker's Avatar
That's exactly what I mean. This will have to be done when I can get parts, not just when I have time to do the job. What size bolts wil I need to buy?
Old Apr 26, 2011 | 10:20 AM
  #40 (permalink)
Dave, as discussed earlier, since you are only doing the fronts, you will require no new hardware (sensors, bolts, etc all will swap over) and only a slight modification to the dust shields, a bend works fine and they will bend with your hands under the right pressure (use gloves )
No problems, get to it and let us know how you like the new braking power....
