Squealfire!!
Old May 15, 2011 | 08:58 AM
MRMARC's Avatar
Default Squealfire!!
Im haveing an issue. Whenever I turn the steering wheel to the left theres a horrible squeal. I was told it's my ball joints but since this is a place of wealth in knowledge, Im asking for a second opinion. Any takers????
Old May 15, 2011 | 09:06 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Squealfire!!
Sounds like a Power Steering pump/belt issue. You will have to provide more info ie. while moving, while parked, low speed, high speed, mileage on the car?
If the squeal happens when you are not moving then you can rule out alot.
Old May 15, 2011 | 09:13 AM
MRMARC's Avatar
It happens when it's not in motion and at low speeds i.e. parking. Its coming from front drivers side. It was subtle at first but know its loud. It doesnt happen at high speeds.
Old May 15, 2011 | 09:15 AM
Originally Posted by MRMARC
It happens when it's parked and at low speeds i.e. parking. Its coming from front drivers side. It was subtle at first but know its loud.
Miles on the car?
Old May 15, 2011 | 09:17 AM
MRMARC's Avatar
Just hit 82xxx
Old May 15, 2011 | 09:33 AM
32krazy!'s Avatar
if it happens when the car isn't in motion then it isn't the ball joints. they will creak not squeal.
btw theres NO NEED TO YELL! WE HEAR YOU!
Old May 15, 2011 | 09:39 AM
You are low on power steering fluid. Doesn't take much.
Old May 15, 2011 | 09:54 AM
MRMARC's Avatar
LOL @32KRAZY! I'll lower my tone. But I didn't figure it was the fluid, It was just at the dealer Friday...hmmmm I'll go check the fluid level now........
Old May 15, 2011 | 10:04 AM
MRMARC's Avatar
......Soooo ....the fluid is low. I feel like a dummy. And usually I'm pretty quick at figuring things out. I never thought to check that. Autozone here I come! I really appreciate the help here!
Old May 15, 2011 | 10:05 AM
It doesn't take much so make sure it is completely full with the correct fluid.
Old May 15, 2011 | 10:07 AM
MRMARC's Avatar
Cool! Im checking the owners manual now to see if there's a specific kind needed.
Old May 15, 2011 | 10:12 AM
It does but I am at work so not much help right now. Needswings site might tell you. Or someone will chime in soon.
Old May 15, 2011 | 10:19 AM
It is Pentosin CHF11S.....not you're average PS fluid. The manual may give you approved alternates though but I'm not sure.
Good luck.
Old May 15, 2011 | 10:36 AM
Thanks man. That is all you want to use. Don't mix it.
Old May 15, 2011 | 10:42 AM
32krazy!'s Avatar
its a peanut oil derivative. don't mix it. wait until the dealer opens and get it there. 1 qt will last a lifetime
and if the mechanic who told you that it was the ball joints is the mechanic who couldn't see it was low on fluid you might want to get another mechanic!
Old May 15, 2011 | 11:50 AM
10-4..............lol
Old May 15, 2011 | 04:02 PM
MRMARC's Avatar
Added fluid and it still squeals. Now I see that its not good to mix the fluids. So I'm assuming the dealer can drain it and fill it with the right fluid?
Old May 15, 2011 | 10:32 PM
you may have air in the power steering system as well since it was low...and you didn't listen to Steve and I to use the recommended oil....it may have to be bled out...look for any of the power steering lines that may be leaking, or the cap, or reservoir....good luck...
Old May 16, 2011 | 07:39 PM
MRMARC's Avatar
Its not that i didnt listen , I was just in a hurry and signed off before I was advised to use Pinsotin. I contatcted my dealer and was told they could flush it for about $60. Finger's crossed , I hope i didnt screw anything up! Thanks again guys!
Old Jun 6, 2011 | 10:04 PM
MRMARC's Avatar
Had the steering flushed and filled with Pinsotin by the dealer two weeks ago, its quieter but still creaks.
