About to order ForgeStar wheels... Can someone check this and make sure it's right :)
Old May 16, 2011 | 04:17 PM
Sheldon's Avatar
Default About to order ForgeStar wheels... Can someone check this and make sure it's right :)
Going to order:
18x8.5 ET+26 for the front
18x10 ET+26 for the back
Car is not lowered now, but will be next year. Brakes are stock, probably will stay that way.
iForged suggested those offsets, is that correct? I tried the wheel calculator thing but I don't know what size tires I should get.
On that note anyone know which size tires I should get
(I apologize in advance, I just don't understand wheel and tire fittings)
Old May 16, 2011 | 06:39 PM
Default Re: About to order ForgeStar wheels... Can someone check this and make sure it's right :)
the front factory factory is 30 and the rear is 20 for the ET (offset) if you have any lip at all add that to the et example 18x 8.5 42 ET with a 2" lip = a rim with a 30 et with no lip. here is a pic of a 17 x 9 with 42 ET and 2" lip. hope this helps.
crossfireDRsmounted001-2.jpg picture by amx1397 - Photobucket
Old May 16, 2011 | 06:41 PM
freakingfastsrt6's Avatar
first make sure to know what series your going with before picking your wheel...as If I can remember the formula series is the only series you can get in an 18 inch sizes...I've bought a few different wheels from them and they are hands down one of the best quality wheel out there! If not theee best!
2nd> rear sounds good....but you may want to go up to a 30 or 32 front and up to 34> you can even step up to a 9 inch width....
Originally Posted by Sheldon
Going to order:
Old May 16, 2011 | 06:52 PM
velociabstract's Avatar
The rear is fine (18x10 ET 26) but I don't know about the front offset. I have a 30 offset on the front wheels on my car. Stock is ET 35 on the front.
Les
Old May 16, 2011 | 07:11 PM
skmaas's Avatar
Installed on my xfire with no problems at all are 19x8.5 30 offset fronts and 20s x 8.5 rears 35 offsets rims are adr spartans ISSUE FREE, would be glad to take close up pics and post so you can see the look and clearence
Old May 17, 2011 | 11:59 AM
Sheldon's Avatar
Same wheels as velociabstract, the ForgeStar F14, but gunmetal instead of silver.
velociabstract have you run into any issues with the 18x9 in the front? I know you have had the wheels for awhile now...
Old May 17, 2011 | 12:07 PM
Ive run a 19x9.5 on one of my srt6's and currently running 19x9 on my wifes with a 235 35 19 in tire front lowered on eibachs....no rubbing and no issues over hear...you just want to make sure your going with the correct offsets
Old May 17, 2011 | 12:09 PM
No issues with the 18x9 rims with the 30 offset. I bought 245/35/18's for the front rims and they rub a little when turned sharply on the bump in the upper front of the wheel well. I am lowered though. At stock height it should be fine. I rubbed that same place with the stock rims and tires after lowering so unless you hammer it in a little, it's most likely going to rub when you lower the car. If you order Forgestar's you need to tell them if you want the metal centering ring or plastic one. For track use and to withstand the heat metal is best, for a comfy ride the plastic is best. You need the lugs and socket from somewhere so I just got them from Forgestar. Normal sockets won't fit in the Forgestar lug hole. I put 18x10's on the back but I think 11's will fit if the offset is right. Anything you want to know, just ask and if I have the answer I'll give it to you.
Les
Old May 17, 2011 | 12:19 PM
Sheldon's Avatar
Sweet thanks for the feedback, I think I will go with the 18x9. Emailing them now, thanks again!
here's your sizing chart...for the forgestar f14 wheels...you may even want to run a 18 or 19x11 with a 23 offset rear...give your car a little more of the staggered look....would almost be a perfect fit~! I have worked with sp engineering for 5 years now and get great pricing from them, so when your ready I will get you some pricing on a set!!
18"
18×8.5 offsets from +26 to +50
18×9.0 offsets from +20 to +55
18×9.5 offsets from +26 to +60
18×10 offsets from +16 to +42
18×11 offsets from +23 to +55
18×12 offsets from +36 to +68
19"
19x8.5 offsets from +26 to +48
19x9.0 offsets from +20 to +55
19x10 offsets from +20 to +44
19x11 offsets from +23 to +55
20"
20×8.5 offsets from +26 to +50
20×9.0 offsets from +18 to +56
20×9.5 offsets from +7 to +43
20×10 offsets from +31 to +69
20×10.5 offsets from +20 to +55
20×11 offsets from +48 to +81
20×12 offsets from +39 to +75
Old May 17, 2011 | 12:31 PM
Before you order the 9's let me tell you why I wanted them. I wanted the widest rubber on the front possible. (245's according to my measurements, 255's were too scary) At the same time I wanted the 245's to be the smallest recommended size for the rim. This helps keep the tread flat on the track at really high side load levels. That happened to be a 9" width. If you want to keep the 225 or 235 aspect on the front I'd recommend 8.5" rims or you'll have the stretched look. It depends on what you want and what size tire you plan on. I can take a picture so you can see for yourself if you'd like.
Les
Old May 17, 2011 | 12:42 PM
Sheldon's Avatar
Les
If you wouldn't mind taking some pictures that would be awesome!
Thanks for the offer freakingfast, but I'm already getting a killer deal
Old May 17, 2011 | 01:12 PM
Here's a photo of the front. As you can see they protrude a little. It looks fantastic but be aware that it throws more rocks and road grime on the rocker panels. As the suspension compresses the tire moves up to the inside at the top so it just clears.
This thread has a couple of pictures of my car with Forgestars.
https://www.crossfireforum.org/forum...gestars-4.html
Les
Old May 18, 2011 | 07:34 AM
Did I scare you away from the 18x9's? For most people 18x8.5 is better. You can get a 245 on a 8.5 rim or stay with a 225. On a 9" rim, depending on the make of the tire, anything less than 245 is going to give the stretched look.
Les
Old May 18, 2011 | 09:43 AM
Sheldon's Avatar
Hmmm now I can't decide, I actually really like the way your car sits. Tires aren't an issue, as long as I figure out what I want I'm pretty sure I have Conti convinced to toss me a set.
It is only 1/2 an inch, I'm not sure why I'm stressing so much
Old May 18, 2011 | 10:49 AM
Go with the 9's....sometimes you just gotta say !@#$ it~!
Old May 18, 2011 | 12:10 PM
Sheldon's Avatar
Agreed, order sent! Now to get some rubber for them!
Old May 18, 2011 | 12:48 PM
What did you order for the rear? If you get the offset right you can fit a super wide rim back there. I have a 25 offset on the rear with my 10's and there's room on the inside.
Les
Old May 18, 2011 | 02:20 PM
Sheldon's Avatar
+30 in the front and +26 in the back
Old Jul 18, 2011 | 08:00 PM
odoherty79's Avatar
cani put these on my stock crossfire? Dub Bomber 5 20x8.5 20x10?
20" DUB Bomber 5 Chrome Wheel Set DUB Chrome RIMS SET | eBay
18"
19"
20"
