a lil teaser for ya!!
Old Jun 26, 2011 | 01:45 PM
32krazy!'s Avatar
Talking a lil teaser for ya!!
i started my big brake upgrade today. caliper is a 2005 340mm 6 piston and the rotors are 340mm 2 piece lightweight rotors from racing brake. they weigh in at 17 lbs!!!!
so you have to trim the dust shield and thats it!! bolts right on.
thanx to jimmyskullz,lantanatx for all the legwork, the fotos , the ebay auctions that allowed me to run this setup. btw if you stay with the 340mm you can run 17" rims!! the bigger 360mm rotors req. at least an 18" rim. the rotors arent cheap but almost half the cost of the oem rotors for the slk55 and lighter. WINNING! as i finish everything up ill post more pics
Old Jun 26, 2011 | 03:51 PM
ZAHANMA's Avatar
Default Re: a lil teaser for ya!!
Looks great Steve! These aren't the RB rotors that Eurocharged is producing now are they? I thought those were only for the 63s
Old Jun 26, 2011 | 05:01 PM
Thirteendog's Avatar
I had to go out and make sure you didn't borrow my brake setup.
Lookin good Steve
Old Jun 26, 2011 | 05:20 PM
Bigkid's Avatar
That really looks good Steve!
Old Jun 26, 2011 | 05:26 PM
PNA's Avatar
PNA
Are you using dust shields? Most on here don't think that's a good idea. If you've been using them, how have they performed? What about issues with rotor warpage etc.? I openned a thread on this a week or so ago and results were don't use them. Maybe it's something different than what I've been investigating to reduce the brake dust?
Old Jun 26, 2011 | 05:28 PM
bmorgan's Avatar
I believe that he is talking about the dust shields that are on the back side of the rotors. Nice looking setup Steve.
Old Jun 26, 2011 | 05:31 PM
JHM2K's Avatar
We've been talking about this for so long, it's shocking to finally see it come together!!
The final product is going to rock even more.
Old Jun 26, 2011 | 05:47 PM
Lol after telling Dylan about it last night. He looked at me and said, "so he's going with the wintergreen look" lolololol
Old Jun 26, 2011 | 05:58 PM
JHM2K's Avatar
Old Jun 26, 2011 | 06:04 PM
PNA's Avatar
PNA
Thanks for the clarification.
Set up looks great.
Old Jun 26, 2011 | 07:55 PM
32krazy!'s Avatar
the rotors are built by r/b. e/c is a distributor for them. my rotors are the c32 rotors which r/b builds to 340mm specs to allow the leading edge of the caliper to contact the outside edge. happens the slk55 calipers are 340mm! so its a perfect fit.
they will also be building a matching 2 piece rotor for the rears but lead time is 8 to 10 weeks and i just bought a set of oem slk55 rotors for the rear so ill use them.
yes the dust shields are on the backside of the rotor. less than a 3" wide piece was cut off to allow the huge caliper to sit on the mounts. took less than 5 minutes to zip it off with a cutoff tool
Old Jun 26, 2011 | 07:59 PM
ZAHANMA's Avatar
Sounds like I need to drive down there and let you install them on my SRT. haha.
Old Jun 26, 2011 | 08:25 PM
32krazy!'s Avatar
I was thinking SNOCAP!!!
Old Jun 26, 2011 | 08:45 PM
grip grip's Avatar
Nice work Steve.
Old Jun 27, 2011 | 12:17 AM
Mimi05SRT6's Avatar
Awesome Steve! I have to get me some brakes just like those someday and with the AMG on the Calipers would be nice! Lookin' good!
Old Jun 27, 2011 | 03:03 AM
simmie777's Avatar
Those are some serious brakes right there! Nice work!
Old Jun 29, 2011 | 03:13 PM
nhmercracer's Avatar
If you could post part numbers, and suppliers for the calipers and rotors, that would be great.
Something like this would finish off your install:
They are available from Azevedo Motorsports online.
Yes, those nuts are incorrect. FedEx has happily spent the last week moving the correct nuts around upper state NY for an extended visit. They should be here Friday.
Old Jun 29, 2011 | 04:14 PM
JimmySkullz's Avatar
Its gonna look great!! I'm glad I was able to help you! I cant wait to see those 2 piece rears! I'll be getting me those also.
Old Jun 30, 2011 | 02:02 PM
Steve, the setup looks AMAZING.
Do not shoot me, I am merely playing devil's advocate here, but why a setup this hardcore? Do you intend on autoXing or other activities extremely hard on the brakes? I only ask because I thought you were more of a straightline guy and it looks like lots of green tied up in this setup. Maybe its the weight reduction or something I am simply not thinking about. Maybe it is simply because they are the coolest thing in brakes I have seen in a while
Old Jun 30, 2011 | 02:23 PM
He want's to be able to dive as deep into the corners as I do... Problem is it's not his brakes that's preventing him from diving into the corner... It's the size of his *****.
They will look really cool though.
