cut srt6 springs and fender height
looking for the front fender to be sitting at around 25" and the rear fender to be sitting about 25.5" could everyone who is running chopped springs please post what spring pads your running, how many coils cut, and fender height? and maybe a run down of the sizes of the different dot pads?
i thought only us Honda guys did that! haha... totally kidding, i do not!
dot 1 pads to dot 5 pads. front and rears different pads. each pad # increases the height by 4mm. most only cut 1/2 coil from the springs and with a#1 pad your looking at 1" or more drop.
I cut 3/4 coil off the front and 1 coil off the back. I had to use a dot 5 on the front or I'd get some rubbing. My front setup was 235/40/18 with a 10mm spacer. On the rear I was having interference with the sway bar and aftermarket adjustable camber arms (only at the track at ridiculous speeds) so I had to go with a dot 4 pad which is the tallest they make for the rear. I believe you can get the 25" to 25 1/2" cutting 1/2 on the front and 3/4 on the rear with the stock spring pads. You'll most likely have to do some adjusting with the spring pads no matter what. It seems not all cars lower the exact same amount. If you search you'll find springs cut much more than mine were without rubbing but my experience was different. (I'm now on K&W's) Don't let the coils get too hot while cutting them. (use lube to keep the temps down)
Les
Les
Les
Les
xfireohio
Jul 20, 2020 12:03 AM
velociabstract
28
Oct 28, 2015 12:46 PM
tom2112
Jul 12, 2015 04:41 PM
