Will these calipers fit. Expert help needed.
Old Aug 11, 2011 | 08:43 PM
grip grip's Avatar
Default Will these calipers fit. Expert help needed.
I'd read on here that SL500 calipers will fit the front with the SRT6 rotors (not with the NA rotors), so I bought them. Now that I've bought them I realize they look a little different than the C32 type calipers I'd seen mentioned.
Anyway, can some of you experts on the subject help me out?
Also, I don't believe the pad locating pins or or other parts are included. Where can I buy them and are they going to cost me an arm and leg?
Thanks as always!
Anthony
Here's the link to the auction I won:
SL500 Mercedes Benz OEM Brembo Brakes Calipers SL55 AMG | eBay
Old Aug 11, 2011 | 09:24 PM
JimmySkullz's Avatar
Default Re: Will these calipers fit. Expert help needed.
I think they use a 330mm rotor.. and the rears are 300 or 315.. I dont think you can get the rears on without a custom mount. as for the fronts, they would need to be spaced with washers and a longer caliper bolt.
Old Aug 11, 2011 | 09:33 PM
grip grip's Avatar
I agree the C32's or authentic SL500's would fit and need to be spaced, but are these really either?
Old Aug 11, 2011 | 09:42 PM
No, the C32 are a direct fit, no spacers needed.. those you bought use a or around a 330mm rotor and need to be spaced out cause of the off set.The C32/C55 and new SLK55 use a 4pot caliper with a 345mm rotor. a direct upgrade for the crossfire
Old Aug 11, 2011 | 09:44 PM
grip grip's Avatar
The C32/C55 and new SLK55 use a 4pot caliper with a 345mm rotor. a direct upgrade or the crossfire
So you viewed the front calipers in the link and I'm good to go with spacers, right? Thanks!
Do you have any idea where I can find the hardware?
Old Aug 11, 2011 | 09:47 PM
you will need to find a rotor that will work, possibly a CLK500 rotor, I think they use a 330mm x 32 rotor.
When you get the calipers the number 330 should be imprinted on the center casting.
As for the hardware, most likely dealer parts.
Steven 4190
Nov 25, 2015 10:12 AM
Mackel
Oct 16, 2015 09:03 AM
ozkancab
Sep 25, 2015 10:55 AM
Sep 25, 2015 07:46 AM
81's
Sep 13, 2015 04:34 PM
