Boot for shock?
I just took delivery of a KONI shock set courtesy of Rob at Needswings. From memory, the stock shocks have a plastic cover over the exposed piston. The KONI's come without. I suspect that the intent is to use the old sleeves (and other parts) on the new shocks. Would there be any advantage/disadvantage to putting on a rubber boot instead of the sleeve? Would condensation be an issue?
Yes, if you read the install instructions it says to re-use the factory boot..... if you wanted to use a rubber boot you would have to find one to fit the shock and not rub the springs.... I would just use the factory one...in fact I did....
2005 Ragtop
Oct 3, 2015 03:01 PM
