Inside of rear tires wear out faster.
Hey guys, I am noticing that my rear tires are wearing faster on the inside part compared to that outside. I always take the car for alignment and general wheel checking around once every 6 months just to be safe and the values for the wheels are in the specified ranges by the manufacturer.
Any ideas what could be causing the inside of the rears to wear down faster?
Yes, I've already searched around the forum, but nothing really stood out to me as a possible cause.
Re: Inside of rear tires wear out faster.
The tires currently on the back are Achilles ATRs, which probably aren't the best of the best hahaha. But how would you rotate the tires +fireamx the way you said, because they have to be mounted on the wheels a certain direction no?
The camber is easy to check, I did a posting on it, just need a ruler and a level. Your rear camber is adjustable, you need the arms to fix it. I adjusted my rear camber to be between the rear of a IRS mustang and a Vett settings. Read the post and youll be able to fix it easy peaszy. Woody
It's a known fact that over inflating the tires would cause the inside to wear faster than the outside. I had no problems with the other 2 sets of tires I had previously set at 36 psi. The General Exclaims with 36 psi didn't run right on my car, so I dropped them down to 32 which did help. Not sure why different tires would have affected it like that.
on
michaelrydquist@msn.com
Or, flip it on its rim and move to other side. Same result, but I'm pretty sure this will result in the TPMS light coming on.
Adrian-x, PM or email me. I make adjustable camber arms, track bars, trailing links and sway bar links for the Crossfire/R170. If you search 'adjustable camber arms' you should find info and pics too.
There can't be much to machining a new bar and it could have the curve for clearance like the OEM one has if I recall correctly. I have never studied this at all but the rear tires I have just replaced had quite a large difference in tire wear inside to out, I hate to see the new ones suffer the same fate, without dismounting and switching them to the other side once in a while.
I think James went for an extra 1/4" pitch and was satisfied with that.
They squeaked a little when first installed, but it stopped as they broke in.
Kodebuster
11-05-2020 04:06 PM
tom2112
07-28-2015 08:12 AM
cjfine
07-20-2015 11:58 PM
