I need your help with bolt pattern size !!!
I have an opportunity to get 4 nice 19" rims with tires that are @ 75%. The guy says they are 5 lug with the bolt pattern 4 1/2. I have no idea if these will fit on the crossfire. The front tires are 225/40/19 and the rear is 275/40/19. Please help and let me know if they will fit. I don't want to travel a couple cities away to take a tire off and try one in to see if it fits!
[url=https://www.crossfireforum.org/gallery/showphoto.php?
on
Re: I need your help with bolt pattern size !!!
Plus, an additional $160 for 4 ( figuring shipping ) would kinda negate the cheap wheel price.
EZaccessory makes just about any wheel adapter you could want. Problem is offset. You'd need to know the offset of the wheels (front and rear, if they are staggered, along with the widths) you're buying before you can worry about adapters.
Post those up and I'm sure we can figure out if it is doable.
Some 5x114.3(4.5") wheels can be put on 5x112 hubs. Flex-bolts or floating seat bolts are available and can be used IF the wheel's lug holes are wide enough. We'd also need to know the offsets of the wheels, they would need to be really high if an adapter is needed...
