Tire rotation
Old Oct 17, 2012 | 07:39 PM
AlexParra's Avatar
Default Tire rotation
Just had wheel bearings replaced on my front, left side; And I noticed the inside of the tire is way worn out about 1/4 width wise. I couldn't have seen that unless the tire is removed.
My question is: After alignment, can I rotate the left tire to the right tire (including rim) so that I can stop the wearing off of and try to get as much life out of that tire as I can.
Also, I suspect that the loud humming noise I'm hearing is caused by that unevenly worn tire.
Thanks in advance for your recommendation!
Old Oct 17, 2012 | 07:50 PM
bluecoupe's Avatar
Default Re: Tire rotation
If they are directional, no.
Old Nov 16, 2012 | 07:06 PM
Clement's Avatar
Cool Re: Tire rotation
I do have the same problem with my rear tire, it used unevently I need new tire. Do I need to rotate my tire..
Old Nov 16, 2012 | 09:41 PM
You can rotate them side to side if they are the original Conti, they were not directional. But the best way is too have the tires flipped on the rim and have them put on the other side. That way what was an inside edge is now an outside edge. It works for directional tires as well. It can be costly but it may get you some additional life out the tires.
James
Old Nov 16, 2012 | 10:12 PM
arejohn's Avatar
What's to be gained. If the tire wore because of a defect and the defect is removed, What changes if you move it to another location?
If the suspension is sound, rotation is not necessary. We do it to mask uneven wear caused by mechanical issues, aggressive driving or to balance F/R differences.
TerryR
Dec 13, 2019 03:27 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
cdcrone123
Sep 20, 2015 10:02 PM
