Re: DIY Rear Cambers
Originally Posted by reiji
(Post 756935)
I'm starting to hear a little bit of squeaking again, but not nearly as bad.
Are there some kind of washers that would maybe help? It seems to me like the bushings in these bar-ends just aren't so great. |
Originally Posted by nhmercracer
(Post 757078)
Here is how i prevented the squeaks.
The Speedway bushings are 1/2 inch internally. The Crossfire uses 12mm bolts for the upper arm. This makes for a sloppy fit when you try to bolt everything up. I purchased four 1/2 inch bolts in the appropriate length. Also, i found eight thin 1/2 inch stainless fender washers. They need to be thin, to allow them to fit between the inner bushing and the mounting tabs. Going to 1/2 inch removes the slop in the system. Also, you will need marine grease. The brand i used is called "Green Grease". When you re-install the joints, use the marine grease in the joint. Remove the bushing, and coat both the bushing and the inner bore of the bushing. Lube the one side of two of the washers, and reinstall in the inner mount. This will tighten the bushing in the mounts, and force the joint to rotate on the busing, not the bushing rotating on the bolt. The outer bushing needs two stainless washers also. Grease the same way, and reuse the large three pointed washer. This washer prevents the arm from falling off if the bushing fails The inner mounts can be drilled out with a step drill bit with a need drive, and a flexible drive extension. I'll post pics later. The outer mount can be drilled with either a long drill bit, or a standard 1/2 inch bit and a right angle drill. I'll post the pics i have, and update this post soon. Pics would be appreciated. What you say makes sense though. I believe the bushings are actually spinning in the bar end and making noise because they're not lubricated.
Originally Posted by turbomar
Spray Krown T40 on the heim joints
My sway bar links have a heim at the top end, but they're not making any noise. |
Not a Heim or rose joint, but still a rod end.
Here are pics of how I drilled out the inner mount for 1/2 inch bolts. http://imageshack.us/a/img266/966/sp40.jpg http://imageshack.us/a/img203/7893/ako5.jpg I reversed the arrangement to do the other side of the mount. Everything is 1/4 hex drive, including the step bit. I had the flex drive, but had to purchase the bit. I spent money for a good one at the local hardware store. The driver is nothing but an electric screwdriver. I added a little lube, and let the bit work slowly. I don't have a pic of the washers, but they are 1/2 stainless fender washers. I brought a caliper, and found the thinnest washers. Installed: http://imageshack.us/a/img20/231/vx3k.jpg I don't have a picture of drilling out the outboard mounting hole unfortunately. I used a short 1/2 bit, and an angle drill. I also used a drill guide. The washers were a slip fit in the inner tabs. They went in with a slight press with a wooden stick. I would call the fit similar to the stock parts. The bolts tightened up nice after assembly. No noise at all with the green grease. |
ttt.
Pics finally. ;) |
(Post 757078)
The Speedway bushings are 1/2 inch internally. The Crossfire uses 12mm bolts for the upper arm. This makes for a sloppy fit when you try to bolt everything up. I purchased four 1/2 inch bolts in the appropriate length. Also, i found eight thin 1/2 inch stainless fender washers. They need to be thin, to allow them to fit between the inner bushing and the mounting tabs. Going to 1/2 inch removes the slop in the system. Also, you will need marine grease. The brand i used is called "Green Grease". When you re-install the joints, use the marine grease in the joint. Remove the bushing, and coat both the bushing and the inner bore of the bushing. Lube the one side of two of the washers, and reinstall in the inner mount. This will tighten the bushing in the mounts, and force the joint to rotate on the busing, not the bushing rotating on the bolt. The outer bushing needs two stainless washers also. Grease the same way, and reuse the large three pointed washer. This washer prevents the arm from falling off if the bushing fails The inner mounts can be drilled out with a step drill bit with a need drive, and a flexible drive extension. I'll post pics later. The outer mount can be drilled with either a long drill bit, or a standard 1/2 inch bit and a right angle drill. I'll post the pics i have, and update this post soon. I have MikeR rear adjustable camber and sway bar links. Great product but bad squeaking. Thanks for sharing your solution |
Just got all my parts... Anybody know the length of the new 1/2" bolts??
I live in a small town and would be easiest to have the bolts bought ahead of time.... Thanks |
Originally Posted by dayjor
(Post 766867)
Stock inner bolt is approximately 2 1/4 inches long. So buy 1/2 by 2 1/2 length fine thread washers, and a locknut.
Stock outer bolt is approximately 3 inches long. So 1/2 by three inches should do. These length DO NOT include the bolt head. Measurements are of the bolt shank only. This is the way they are commonly spec'd. |
Thank you so much for the time and info.....
Appreciate it! |
Originally Posted by syfi
(Post 712854)
Just had the Konis installed (Thanx Rob for the Black Friday Deal!)
Still, I'm a little leary about using SS threads and rods. I've stripped way too many threads in the shop as SS still seems too soft and gummy for my liking. MikeS --------------------------------------------------------------------------------- However, I do wonder what alloy SS you've been using. I am not a metallurgist, but carbon steels and SS come a large variety of alloys. The SS we normally use in our automotive work is anything but "soft and gummy". In fact, it is dang HARD. The SS bolts, flanges etc on stock exhaust systems are way harder than carbon steel. Try cutting those fool things with a hack saw. Have to use a zip wheel as it dulls the teeth on the hacksaw blade. We used all SS rod ends, bolts etc on our formula ford cars back in the day when I actually drove one of those things. |
Originally Posted by hpmotors
(Post 773286)
Non-magnetic and strong SS is a short list. We use A-286. You can get 1300 MPa yield, 1400 MPa tensile. It's the only precipitation hardened austenitic, essentially an iron-base superalloy. And don't forget Inconel. Very difficult metal to shape and machine using traditional techniques due to rapid work hardening! ;) |
Yep - lots of different alloys in both carbon and SS.
Funny you should mention Inconel. Just bought 8 studs for some turbo installations. $20 each! That X-15 pedigree probably drives up the cost! |
(Post 773990)
Hi guys,
This might be a dumb question... Once the parts are all here..how do I put them together? I know I know... Is it one end with LH and the other with RH? Or are they dependent on the side of the car they will be on? Ex: one set all LH and the other set all RH. Seriously...I have the parts in the online cart. I'm doing this =) |
From what I remember there is only one way to thread them into the tube. One set of threads on the end of the tube is for LH and the other set of threads is for RH. The idea is that once both ends are threaded into the tube you should be able to hold the ends tight, rotate the tube and the ends will either come closer together or drift further apart.
Make sure you install the lock nuts between the tube and the ends so you can lock them down when adjusted properly. |
What about the fronts, is this the same solution?
Originally Posted by Timesnow
(Post 794979)
Your Parts Search Returned 1 Part(s) Update 6/29/2019: Another supplier... FCP Euro http://www.fcpeuro.com/products/merc...kit-2023300118 |
http://www.summitracing.com/parts/aaf-all57162
Summit seems to be out of the gold rod, there is a link to the same thing in black on above URL. James1549 said 12 inches is a good ballpark to be rid of the excess negative camber. The rod is listed as being 9.0 inches long, is the other 3 inches (1.5 in per end) of installed length coming from the exposed threads of the 2 rod ends? That seems like a lot. How long is the threaded part of the rod end? Hopefully there's plenty inside the tube. Would 10 inches tubes be more suitable? Summit lists those also. |
Originally Posted by ZX2 Nick
(Post 796403)
Summit seems to be out of the gold rod, there is a link to the same thing in black on above URL. James1549 said 12 inches is a good ballpark to be rid of the excess negative camber. The rod is listed as being 9.0 inches long, is the other 3 inches (1.5 in per end) of installed length coming from the exposed threads of the 2 rod ends? That seems like a lot. How long is the threaded part of the rod end? Hopefully there's plenty inside the tube. Would 10 inches tubes be more suitable? Summit lists those also. Let's put it this way...9" tube w/ both rod ends screwed all the way in will give around 11-1/4", so 12" will expose maybe 3/8" of threaded shank on each end. So yes, most of the threaded shank is in the tube. Price for the same mfg rod I quoted from EastCoastSpeed is cheaper w/ free shipping.:eek: |
I am ordering all the pieces right now. But they are out of stock on gold steel rods so I will try to find them from a different source...
Thank you for the info!!! |
