Big Brake Upgrade
Old Mar 11, 2013 | 05:20 PM
grip grip's Avatar
Default re: Big Brake Upgrade
The 6 pots arrived today in Venice, FL where we're visiting family for the next week. The wife calls it a vacation.
Anyway, I was a little surprised at the size of the calipers, so I took a couple photos for reference. I think I'll hold off on painting until after I get them fitted on the car. Please pardon the beachwear.
Moreover, if the Brabus wheels don't fit with these, the wheels will be the ones that will be finding a new home.
Old Mar 11, 2013 | 07:07 PM
Those are huge. You will need those soft padded things for your shoulder harness.
Old Mar 11, 2013 | 07:34 PM
32krazy!'s Avatar
are those temporary tatoos? and whos arms did you fotoshop onto your body? btw i like the calipers!
Old Mar 11, 2013 | 07:59 PM
Whoapony's Avatar
Those are gonna look great on the car, can't wait to see them installed!
Old Mar 15, 2013 | 10:40 PM
grip grip's Avatar
Vacation is over and I've got my noodle-arms to work on mocking up the fronts. Click on the second image to see "the wheels on the bus go round and round".
After fitment, I pulled out the Ricer Paint. Will they become SRT or AMG Calipers????
Old Mar 16, 2013 | 01:54 AM
grip grip's Avatar
Here's a couple photos of the calipers with the correct insignia:
Old Mar 16, 2013 | 07:47 AM
Whoapony's Avatar
Man that looks good! Not rice at all in my opinion and really makes those bad boys stand out!
Old Mar 16, 2013 | 07:52 AM
32krazy!'s Avatar
ill be there after the car show. did you get the crossover lines off?
Old Mar 16, 2013 | 08:28 AM
grip grip's Avatar
Thanks.
I didn't need to. All I had to do was swap the brackets.
Old Mar 16, 2013 | 11:06 AM
Bigkid's Avatar
Grip thoes calipers look great. Where did you get the logo's, I have four places I would like to stick some
Old Mar 16, 2013 | 03:28 PM
grip grip's Avatar
Thanks. I got them off ebay. Here's a set below I just found doing a search:
http://www.ebay.com/itm/6-Brembo-Brake-Caliper-Decals-Stickers-Emblems-Pads-Parts-/171006936360?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d0cec528&vxp=mtr
Old Mar 16, 2013 | 06:51 PM
grip grip's Avatar
They are finally fully installed and working. I've got a small leak to figure out, but other than that everything went off without a hitch.
Here's the folder if you want to see the photos that didn't make the cut: 1 - Brembo Brakes On The Crossfire Photos by wheelus928 | Photobucket
Old Mar 16, 2013 | 10:31 PM
Bigkid's Avatar
Thanks for the link Grip.
Old Mar 16, 2013 | 10:45 PM
JesseJamessrt6's Avatar
Awesome look grip, well done! Thanks for all the pictures in your link.
Any way you could shed some light on the all the details of what MB models and which combinations these all came from?
Old Mar 17, 2013 | 07:48 AM
cmz's Avatar
cmz
very nice.
Old Mar 17, 2013 | 08:26 AM
Now that is a set of brakes....Nice work Anthony....
Old Mar 17, 2013 | 10:05 AM
grip grip's Avatar
The calipers are from a clk55 (2005+).
The front rotors are from a C32 (since I wanted to go with 345mm instead of the super expensive 340mm SLK55 / CLK55 rotors. The rear rotors are from a SLK55 / CLK55 (330mm).
The rear rotors and calipers are a 100% bolt-on and go. Even the retainer screw that holds the rotor on lines up.
On the front rotors, the retainer screw didn't line up, so I had to use a lug bolt to keep the rotors in place until the caliper was installed. As for the caliper, I had to space it out 2.5mm (1 washer) to accommodate the extra 5mm in rotor diameter. I installed 1 washer per bolt between the removable mounting ear and the caliper itself.
Good luck.
Old Mar 17, 2013 | 12:46 PM
  #38 (permalink)
JimmySkullz's Avatar
Looks Awesome! I like the color choice, I was thinking of eventually color matching my caliper to the body color, SSB. Right now im still Silver with the AMG logo.
Old Mar 17, 2013 | 01:07 PM
  #39 (permalink)
The calipers are from a clk55 (2005+) or CLK55 (2005+).
Good luck.
Thank you, this info is golden. Time to start hunting! Once again your setup is killer, looks really sharp.
Old Mar 17, 2013 | 01:16 PM
  #40 (permalink)
JHM2K's Avatar
Amazing setup, Anthony!! Love it bro!
