Changing Brake Fluid
After reading a few threads about the importance of brakes,I wanted to ask everyone about changing the brake fluid. Is this something I can do myself as I have never done it before? I already purchased 3 bottles of Motul RBF600 just not sure what to do with it!
Thanks
brake fluid
power steering fluid
hydraulic top pump fluid
differential fluid
in both of out roadsters.
Max had bought an air compressor powered brake fluid sucker, and it sure worked GREAT !!!
The compressor causes a vacuum in the canister that connects to the caliper, and it came with a bottle and mount that you put the new fluid in and mount inverted over the master cylinder reservoir, kinda like a dog's water bottle thing.
Here's an inexpensive kit from Harbor Freight :
Brake Fluid Bleeder
I've used the friend pumping the pedal method and gravity bleeding method. If you have the time gravity bleeding works great and best of all, you don't need special tools.
Les
Les
I use this: Mityvac
Don't forget to use some Teflon tape on the bleeder nipple threads, ( don't block the hole!) This thing works great, and you can do it without help.
And they recommend using silicone grease on the threads and not telflon thread tape. And I have to agree.
This is the unit I bought. However, in the instruction manual for it the thread leak is addressed. So long as you keep the suction going while you close (tighten) the bleeder screw the last time, no air can be introduced to the system.
Rated to 175 degrees F, it can be used (in 4 or 5 steps-2 quart capacity) for changing the motor oil too. After a short wait from operating temp, of course.
But I'm old-school. I still crawl underneath and replace a copper gasket when I do mine. Peace of mind and I can look stuff over.
Back in the fifties and sixties when we did not know about or cared less about pollution, we dug a hole in the gravel driveway and unscrewed the sump plug. No problem, we were just putting it back where it came from.
I guess that's almost a hanging offense these days.
I did recycle oil though, I drained it into glass bottles, let it sit for six months and let the black crap settle to the bottom. I then added some oil additive to the clear oil and put it back in my old 350 BSA as a top up supply.
You mean: you actually have to pump that thing? With your hands?
How...quaint!
How...quaint!
Maybe you should have bought a Yugo and not a Crossfire
I guess you don't change oil because of the cost as well?
Mityvac makes this model and an air operated on. Easier this way, you don't have to deal with an air hose attached.
If I'm bleeding brake lines, I'l pull all new fluid from the Master.
One thing Max didn't mention : on both of ours, the OEM fluid was kinda burnt orange/gold colored, the new fluid was blue. It was easy to see when all the new stuff had replaced the old stuff.
And some thing neither of us mentioned:
On the tin of ATE Blue Racing Brake Fluid, it states in big, bold letters that it is NOT approved for on-street use due to it not being "fluid standard color compliant" or some such crap.
Is that the EPA black helicopters I hear approaching?
And, if one calculates the volume of the longest line, right, rear it's no more than ~1-2 fluid ounces. A good guide for how much fluid to extract when bleeding, no?
