Wider Tires on 2004 Coupe
Old Aug 20, 2013 | 12:50 PM
autumnmass's Avatar
Default Wider Tires on 2004 Coupe
I was thinking of going with a wider tire on the rear wheels (2004 coupe) since reading the forum it seems a lot of members have wider rear tires. I just wanted to know if I would require any spacers if I used my OEM rims. I was going to put 275/35/19, the Hankook Ventus V12 EVO K110. Thanks for any info you can provide.
Old Aug 20, 2013 | 12:55 PM
Default Re: Wider Tires on 2004 Coupe
Make it 285's ! Im on my second (or third?) set.
Read this thread:
https://www.crossfireforum.org/forum...-evo-k110.html
If you don't like Hankook, get what you do like - just know that 285's will fit without problems or spacers.
Old Aug 20, 2013 | 05:45 PM
Beaner's Avatar
That is the perfect size! Order them up. no spacers or anything like that needed
never mind the 285...
Old Aug 20, 2013 | 05:52 PM
syfi's Avatar
General G-Max 275/35/19 on my 05 N/A Limited on stock rims. Perfect size and great tires. 235/40/18 on front too!
Old Aug 20, 2013 | 08:41 PM
Squirrel Crusher's Avatar
Go Wide-No Problems Bridgestone Potenza front and back. Factory wheels without spacers. I did un-necessarly trim 3 threads off the front ball joint just because I didn't have anything to do at the time. Front and back have a slight sidewall buldge which will protect your wheels from curb rash. No unsual tire wear or rubs. Front-245/35/18 ** Back-295/30/19 Squirrel Crusher
Old Aug 21, 2013 | 06:39 PM
syfi's Avatar
Hey Squirrelly, how about posting up some pics of those monsters? And do the 295/30s still have a decent sidewall height compared to the fronts? I'd like to see a side shot to see how close yours comes to the outside wheel well edge. And I'll bet they look awfully meaty from the back!
Old Aug 21, 2013 | 11:09 PM
I only have a 35MM film camera. There's pictures of it at last years Fall Dragon. I'll be at this years Fall Dragon with the same tires. I'm really considering cutting out my rear outer fenders and fenderwells to go wider. Thinking Michelin Pilot Super Sport 305/30/19 on 11" wide wheel. Squirrel Crusher
Old Aug 21, 2013 | 11:46 PM
+fireamx's Avatar
I'm with Squirrel Crusher. If you go with a 275, 285, or 295 I recommend going with a 30 series.
The 35 series will fill up your wheel well better, but will effectively give your car a "higher" gear ratio.
Slightly better MPG, but slightly slower accelleration. So I guess it's a matter of what is most important to you.
IGot2P
Jul 26, 2025 12:40 PM
Kodebuster
Nov 5, 2020 04:06 PM
northwest_crossfire
May 30, 2016 05:19 PM
Romio
Jul 24, 2015 07:04 AM
KwehCat
Jul 16, 2015 04:48 PM
