Would this fit on the CROSSFIRE
Old Nov 6, 2013 | 01:35 PM
AnthonyCF's Avatar
Question Would this fit on the CROSSFIRE
Does anybody know if this size of wheels will fit front 20 8.5 offset 35 Rear 20 9.5 offset 40 .The back offset has me stuck any help wheels are Voxx Borsa would sure be appreciated thanks .
Old Nov 6, 2013 | 03:58 PM
Default Re: Would this fit on the CROSSFIRE
The rears will need pretty large spacers, at least 15mm, the fronts should be close. I would advise against going with 20s on the front, I did on my last XF and the tire profile is so small that if you have a loss of pressure, as I did, there is no time and you are in for a ride, I totaled mine.
I did an 18/20 stagger on my current car and really love the look, plus it keep the natural rake from the factory that really helps the car look perfect. My old rims were very similar, here is a photo...
Old Nov 6, 2013 | 08:08 PM
cg80's Avatar
Cool Re: Would this fit on the CROSSFIRE
John... That is one beautiful Crossfire!!!Carl
Old Nov 6, 2013 | 08:13 PM
cg80's Avatar
John: Just noticed your Carbon Fiber headliner...did you install this yourself...if so degree of difficulty??
I have carb on fiber wrap on the windshield molding as well as the side strips...looks good ...Carl
Old Nov 7, 2013 | 08:41 AM
Thanks Carl! We pulled out some trim pieces and removed the headliner, pulled all the old fabric off, prepped it, sprayed it with 3m adhesive through an air gun and molded the material into place, then reinstalled. Degree of difficulty is all relative as I don't know how comfortable you are with taking apart the car or what mechanical knowledge you have...
It is difficult to get the headliner in and out of the car, but you must do it through the passenger side and it is a very tight fit just FYI
rayth
41
Jul 31, 2019 04:02 PM
Snake Eyes
Jun 21, 2015 04:19 PM
Tommyj
U.K.
Jun 16, 2015 07:21 AM
Wikky
Jun 14, 2015 12:17 PM
MJPowers
Jun 8, 2015 02:34 AM
