Camber kits question
Old Dec 13, 2013 | 08:04 AM
Default Camber kits question
Guys, I have lowering springs, and I see the tires that came with the car has more wear on the inside if the tires. I'm taking it for a alignment. Are there front and rear camber kits available or just fronts?
Old Dec 13, 2013 | 08:40 AM
Default re: Camber kits question
FP the front bolts, Needswings has them .
the rear gets the chamber arms like MikeR use to make.,, I may have a set of his,, I replaced all rear arms with Rudy's adjustable set. jim
Old Dec 13, 2013 | 10:22 AM
Default
How many degrees can you adjust with the front kit?
Old Dec 13, 2013 | 02:33 PM
about .03 to .05 I think but that is all you need to aline it for street use. hope it works for you.jim
Here are my settings
front left camber -1.3 / caster 4.9
right front camber -1.2 /caster -4.7
Toe left front 0.68 // right 0.16
Left rear camber -1.1 toe 0.01
right rear camber -1.0 toe 0.31
left total toe 0.32
Old Dec 13, 2013 | 03:30 PM
Adding the Eibach lowering kit require a 1 degree alignment adjustment. So, I have the TVT camber kit coming from the original owner of my car. I guess I can go with the NeedsWings front kit for the front if they can provide the 1 degree adjustment.
Old Dec 13, 2013 | 06:19 PM
maxcichon's Avatar
Default Re: Camber kits question
FP, I was able to get within spec on the front using the MB/Chrysler "Collision Kit" bolts. The rears require MikeR's adjustable arms or equiv. I made a pair of my own.
If you buy TVT-style, make dammed sure they are not aluminum. Someone from our forum had one FAIL at the Dragon recently. Bad mojo.
And the lowered arms may interfere with the rear sway bar. I cut mine into an hourglass shape to provide a little clearance. There are photos in my old gallery. If you can't find them-PM me and I'll email them to you.
Old Dec 13, 2013 | 06:54 PM
Thanks Max.
Old Dec 13, 2013 | 09:44 PM
TommyT's Avatar
If you canhold off for just a bit longer, Ground Control will have something for you.
Old Dec 23, 2013 | 12:14 PM
mobilefitt's Avatar
anyone see or try these??
http://www.ebay.com/itm/SPECIALTY-PRODUCTS-28840-Alignment-Camber-Kit-/331033866364?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CMake%3AChrysler%7CModel%3ACrossfire&hash=item4d1327f07c&vxp=mtr#ht_1264wt_930
Old Dec 28, 2013 | 01:01 PM
nhmercracer's Avatar
Default
For the front? That is where the real issue is. The best solution would be adjustable upper arms. The K-Mac bushings work, but the adjustment is limited. I can only dial back to -1.7 degrees in the front. An adjustable ball joint like the Crown Vic, which allows caster and camber to be adjusted independently.
UNDER PSI
Nov 1, 2015 09:39 PM
Idrenak
Sep 19, 2015 08:17 PM
ayebb
Sep 18, 2015 03:35 PM
Valk
Sep 17, 2015 11:43 AM
Big Daddy
Sep 10, 2015 10:21 PM
