Widest rears on stock rims
Old Feb 12, 2014 | 11:21 PM
2008XF's Avatar
Default Widest rears on stock rims
Hi,
What is the widest and best size on stock rims for the rear?
Old Feb 12, 2014 | 11:27 PM
Selbyl's Avatar
Default Re: Widest rears on stock rims
I know 285/35/19 is safe, I've heard of a few running 295 or 305. Also heard one guy using 285/40/18 since 19's are harder to find.
Old Feb 12, 2014 | 11:29 PM
2008XF's Avatar
i didnt want to go that wide because I drive alot. How will it affect gas mileage. I drive close to 40,000 km a year.
I was thinking 275-35-19
Old Feb 13, 2014 | 12:35 AM
JEFASOLD's Avatar
Originally Posted by 2008XF
Hi,
I know a lot of guys put some really wide rubber on the OEM wheels but go to Tire Rack and you will find that it is not recommended to go too wide and it is for good reason. Pick a tire you like and check the specs page and it will show the rim width recommended for each tire size and the minimum and maximum, Tire Rack does know what they are talking about.
Old Feb 13, 2014 | 09:10 AM
syfi's Avatar
Have read alot of comments about the 285s being about the most extreme you'll want to go. Depending on the tire mfg, some had trouble getting them to seat right. 275s are about the safest width to go with.
Old Feb 13, 2014 | 09:44 AM
2008XF's Avatar
going 275 vs 255 how much will it effect my fuel efficiency
Old Feb 13, 2014 | 09:50 AM
sk8erjosh09's Avatar
Maybe 1-2 mpg per tank. I run 275's and need to go wider. I think 285's will be my next tire purchase.
Old Feb 13, 2014 | 12:31 PM
cjw's Avatar
cjw
I had a 295 30 19 michelin ps2 on the stock srt rim no problem, little harder to mount but ran fine
Old Feb 13, 2014 | 01:24 PM
Da55id's Avatar
I'm running 283/35/19 on stock SRT6 rims with zero problems, and they look great...and also give that extra little bit of curb rash protection as a bonus
Old Feb 13, 2014 | 07:56 PM
2008XF's Avatar
thanks guys for your help. i am going to go with the 275
Old Feb 13, 2014 | 09:07 PM
I have 275 on the roadster and 285 on the coupe. Each tire manufacturer is going to be just a little different.. but going the 275 route you will be fine....
tom2112
Dec 1, 2015 09:02 AM
velociabstract
Aug 7, 2015 01:30 PM
tom2112
Jul 28, 2015 08:12 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
axnguyen
Jul 21, 2015 11:41 AM
