Adjustable Rear Camber Arms
on
on
Re: Adjustable Rear Camber Arms
Has anyone here used any of the following on their Crossfire?:
MB-Arts Adjustable Camber Arms, MB-170-ARCA
Top Speed Pro-1 Performance TRMBENZ-RTCA
(They list these as fitting numerous MB chassis in addition to the R170)
Megan Racing lists a part for the W203 and W208 ,MRS-MB-310, that can be had for under $200.00...
(Would be a good buy if I knew they would fit)
Top Speed Pro-1 and Megan use 4-bar rod ends that have the threaded stud welded to the bar end tube. Have read many accounts on other forums about the weld giving way to stress cracks from inferior welds. (I.E. the weld only attaches the outer edge of the stud to the tube). Also, both use smaller-width 4-bar ends whereas the rubber inserts and center sleeves extend past the bar tubes allowing the rod to flex and degrade the rubber.
The Speedway 4-bar rod ends are much stronger being solid forged and the right width to fit in the holders. No flexing and the nylon inserts are more solid. You don't really need a ball end that's moveable and it's been proven that you don't need rubber inserts (see MikeR's setup) to work right. Someone also was worried that the hollow tube wasn't strong enough. The DOM steel tubes are about as strong a steel tube as you can get and are made to collapse to avoid damage to other suspension parts. But these are referring to racing setups where the stresses are 10-fold. On our cars the force needed to collapse the tube would only result from a totalled rear end collision.
In the end you are only paying for the painting and stenciling on the arms that probably have $50 worth of material involved in their makeup!
Does that look familiar. That just happened to me yesterday at 60 mph. Freaky! Exact same break location.
Here is a link to the part I think that should work best for us....
Mercedes Benz R170 SLK-Class 1998-2004 Adjustable Rear Camber Arms pair
on
Any of the options out in internet land will work if your not lowered .... and don't need them! If your lowered, NONE work. Clarification, they will allow you to get the alignment in spec and all will be fine until you push the car hard, hit the sway bar causing the rear of the car to suddenly jump sideways and end well or poorly depending on your improvisation abilities with the steering wheel. I haven't found the "perfect" solution yet and I've tried a few of the options available.
Les
Les
on
Les is right. I have the DIYs on both Xfires cause the inner treads on the backs were wearing abnormally. Neither car is lowered and both are running 275/35-19s on the rears. DIY cambers corrected both cars nicely. I don't race/autocross either car. Just "spirited" driving so no problems. Like I've stated before, you'll get the same results from the $80 DIY setups as you will from the $240 brand names if all you're doing is simply correcting the inner tread wear anomaly. DIYs have been tested on both my cars for over 1-1/2 yrs with absolutely no problems.
on
what's the wall thickness on those?
Would these (pg. 30) be any better? Just the bent tubes with 5/32" wall (.156").
$31.46/ea. (11")
http://www.out-pace.com/op_2012_cata...al_catalog.pdf
One can find the 5/8" or 3/4" LH/RH rod ends one likes.
I think these would work. Cheaply.
on
Which bar length ?
on
