spacer
Old Jun 12, 2014 | 02:34 PM
austinbarrylee's Avatar
Default spacer
I am getting 15mm spacers for the rear. How long bolts should I get. I have seen total bolt length 1.5 at pep boys. Will they work or need longer. If anyone has link to some on ebay please post. Thanks.
Old Jun 12, 2014 | 02:58 PM
Default Re: spacer
Let's see now, the stock bolts are 40mm which is 1.57", is 1.50 " long enough with another 15mm (.59") added to the grip length? Hmm
Old Jun 12, 2014 | 03:03 PM
Default Re: spacer
Hmm NO!! Didn't know size of stock bolts. I can add. I do have a college degree.
Old Jun 12, 2014 | 03:05 PM
Default Re: spacer
Also had to shave rear bolts for aftermarket wheels so didn't mess with ebrake
Old Jun 12, 2014 | 03:22 PM
Default Re: spacer
Lacking a crystal ball (joke) I did not realize that you had new wheels. When you ask for some aid it is best to put all the info on the table so to speak.
I know squat about wheels and such but isn't 15mm a bit much for spacers? I may learn something here that I never thought I would want to know.
Old Jun 12, 2014 | 03:27 PM
Default Re: spacer
Many have ran 15mm on here. I have done my research but no one has said the bolts size. Maybe cause when you buy some spacers they come with bolts. Mine will not.
Old Jun 12, 2014 | 03:35 PM
Default Re: spacer
When you buy spacers I am sure that you have to specify what length you need unless they know already.
You need ball nuts not conical remember.
Old Jun 12, 2014 | 09:37 PM
JEFASOLD's Avatar
Default Re: spacer
Maybe not, remember he has new wheels, my new wheels use conical bolts. Also I am using 20mm spacers with 275-30s in back.
Old Jun 12, 2014 | 09:40 PM
Default Re: spacer
True, I forgot why I was giving him *****.
He should keep all his post together, not post random threads as thought come into his head.
As I said I know squat about wheels and fitting them as I have not seen anything that much better than the OEM ones that would induce me to spend good money on them. Some of those wheels on here are hideous to my eyes but probably great in the eyes of the buyer.
As far as I am concerned some peoples taste is just in their mouth, but that is what makes us different, thankfully.
Old Jun 12, 2014 | 09:44 PM
Default Re: spacer
275 30 19?
maxcichon
May 14, 2019 07:30 PM
grip grip
31
Sep 27, 2015 10:06 PM
Sep 26, 2015 10:21 PM
04Fire
Sep 15, 2015 07:40 PM
Buchacho
Jul 9, 2015 04:13 PM
