Widen NA rim to 11"
Hi fellow XF enthusiasts,
Have anyone widened their NA rims in the rear?
I am thinking of making them into 10-11" rims and smack a 295/30/19 on there..
Any experience of this?
That will drastically change your offset.
Can they widen a "cast" aluminum wheel?
Stock wheels are 29 lbs apiece in rear, that plus the big **** spacer will add lots of rotational weight.
Are you set on stock wheels?
There are several of options for 18x8-8.5 19x10-10.5-11 "if" you redrill the rear hubs to a 5x114.3 and use a 73mm- 66 mm hub spacer.
Even lightweight roto formed wheels. You could take around 15-20 lbs of rotational weight off the rear wheels.
Think I will stick to stock NA as I like the looks. same weight as SRT-6 wheels in front. Rear is like 2 lbs heavier only.
I want to prevent the 285/30 to look so dame fat from side on the NA rims..
I see you're in FLA but here has to be a place like this down there.
If you were in MI you would go here Weldcraft Wheels Wheel Widening Wheel Repairs Wheel Restoration
velociabstract
28
Oct 28, 2015 12:46 PM
Power Sedan
Sep 20, 2015 09:24 PM
caseydeankopp
Sep 13, 2015 07:25 PM
