How far from Spec is your camber ???
Old Feb 9, 2015 | 06:38 AM
wvwonder's Avatar
Default How far from Spec is your camber ???
My camber is out more than 2.0 but its negative camber and I have heard that makes your car handle better. What camber does everyone else have ? whats that do to tread wear ?
Old Feb 10, 2015 | 05:54 PM
Beaner's Avatar
Default Re: How far from Spec is your camber ???
This is what my car was set at last time I had an alignment. Front tires have not shown any signs of wear. my rear tires show camber wear and I plan on straightening them out a little bit in the spring time. With my wider tires (285) makes it more visible than it would on the factory (255)
Old Feb 11, 2015 | 12:39 PM
mobilefitt's Avatar
My car handled better before I brought the rear in spec. Riding on the inner-edge of the rear tires made my car carve turns up like crazy. I never had tire wear and it was about 2 degrees out. More body roll, and bumpy turns now that my tires are flat. I wanted to prevent tire wear so even though it wasn't broke, I went ahead and fixed it.
I like having green on my alignment report, but I liked how my car handled before. If your tires aren't showing premature wear, enjoy driving your car the way it is now. I believe my lap times would have been better if I were tracking the car with a bit of negative camber.
Old Feb 12, 2015 | 07:49 AM
wvwonder's Avatar
-1.3 front camber would be good. I think I have to much,inside of tire is wearing. Do you think 1.5 adjustment would stop wear?
I read that's the max I'll get from Mercedes bolt. And the K-Macs are so expensive. (480.00)
These are my alignment numbers :
Old Feb 14, 2015 | 09:49 PM
wvwonder's Avatar
I don't know if it has been lowered or not, but I wonder if there is a cheaper way to get it into spec. Does anyone know if I replaced the springs or something else, would it work ?
UNDER PSI
Nov 1, 2015 09:39 PM
velociabstract
28
Oct 28, 2015 12:46 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 26, 2015 10:21 PM
lazorouss
Sep 11, 2015 09:16 AM
