Smaller wheels/larger tires?
Old Sep 1, 2015 | 07:17 PM
RedNeck's Avatar
Default Smaller wheels/larger tires?
Didn't see what I was looking for in the sticky so sorry if I missed something. Extremely close to buying an 05 base model and was wondering if anyone has gone down in tire size? I know the 04 Slk320s came with 16/17, is that possible on the crossfire? What issues might I run into? Thanks
Old Sep 1, 2015 | 08:07 PM
chturner's Avatar
Default Re: Smaller wheels/larger tires?
Is there a specific reason you want smaller sizes? Or are you looking at one with smaller tires?
Old Sep 1, 2015 | 08:08 PM
chturner's Avatar
But to answer your question, I have seen people on here run 17's on the track. I don't think you would have trouble. You would just look unproportional
Old Sep 1, 2015 | 08:19 PM
RedNeck's Avatar
2 reasons: To possibly soften the ride a little, and there's a small chance I may drive it in the winter
Old Sep 2, 2015 | 12:19 AM
syfi's Avatar
I went with 1 size over on front (235/40-18) and 2 sizes over on rear (275/35-19). Both sizes fit on the OEM rims and give a taller sidewall, thus a softer ride. Check out Toyo Proxes 4 Plus AS tires for great all season driving.....
Old Sep 2, 2015 | 11:43 AM
RedNeck's Avatar
Was there any speedometer calibration required or was it not enough difference to worry about?
Old Sep 2, 2015 | 12:25 PM
velociabstract's Avatar
Smaller diameter rims are going to be difficult on the front because of the brake calipers. Not just any 17" rim will work. You may find a 17" rim that will fit with lots of measuring or trial and error. The rear has lots of room and most 16" rims will fit if you so desire.
Les
Old Sep 2, 2015 | 01:45 PM
syfi's Avatar
Not enough to worry... maybe a mile or 2 per hour difference.
I have those sizes on both of my XFs and never a problem!
Also have the General G-Maxs on the Limited. 42K on the first set and on the second set now. Great prices and compairable to the Pilot Sports!
Not lowered. Still @ OEM height w/ KYB shocks all around.
Have the DIY rear cambers and front eccentric bolts installed with a 4-wheel laser alignment for perfect tire wear.
Mike S
Old Sep 2, 2015 | 11:57 PM
Like las said in the front you will need to find a rim that clears th brake rotor.
as long as you use a tire that is 26 to 27" tall in th rear you will be fine ( no changes to the speedo or anything else.
stock is front 25.1 tall,,rear is 26.0
You can use ,,,front 17' rim,, tire 215/50-17,,235/45-17,,255/40-17,
you can use ,,rear , 17" rim,,tire 285/40-17, 255/40-17,255/45-17
front 16" rim.. tire 225/50-16,,205/60-16,,245/45-16
rear 16" rim,,tire 255/50-16 ,,265/50-16 255/50-16,, 275/50-16
good luck jim
Old Sep 3, 2015 | 07:23 PM
RedNeck's Avatar
Thanks for all the advice guys..will know more about the path I take when I pick up the car in a few weeks. Just put a deposit on an 05 with 19k miles..
TerryR
Dec 13, 2019 03:27 PM
Jonacross
20
Jul 17, 2017 11:19 PM
Mackel
Sep 29, 2015 02:41 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
stelrz1
Sep 21, 2015 11:18 AM
