What are the multi star bolts used on rear suspension
Old 01-18-2016, 01:52 PM
ardenian's Avatar
Default What are the multi star bolts used on rear suspension
Replacing all the wishbones etc. What are the multi star bolts used on them are they some sort of torx screw?
Old 01-18-2016, 02:01 PM
Default Re: What are the multi star bolts used on rear suspension
I know the one at the hub for the camber link is a T55 ......
Old 01-21-2016, 05:22 AM
ardenian's Avatar
Thanks for that, sod's law the only torx sockets I have go upto T50.
Old 01-21-2016, 06:16 AM
That was also my case, had to go out and buy a T55 to install my adjustable rear camber links.
Old 01-21-2016, 10:40 AM
boostmonkey's Avatar
Default
If I recall there were one or more 12 point triple-square bolts back there.
Old 01-21-2016, 06:05 PM
Toolman's Avatar
After I installed my adjustable camber kit I took it to the local Tire's Plus for alignment. After checking the car in the counter person said they would not provide a Lifetime alignment warranty option I wanted with the aftermarket parts on it. I talked with the mechanic afterward and he said he did not have the T55 bit. I took the car to Firestone and they did the lifetime alignment. I asked why they already had my car in the system and learned the same company owned Tire's Plus.
Old 01-21-2016, 06:47 PM
Squirrel Crusher's Avatar
Yes,There is a 3square 12MM bolt back there. NAPA bit set sell for $68.00. Harbor Freight's 3square set is less than half the cost. Squirrel Crusher
Old 02-26-2016, 12:52 PM
Look for XZN kits on Amazon.
slide93
10-07-2021 03:33 PM
treyleblanc
11-07-2017 01:18 PM
Crossfire777_
12-31-2015 12:42 AM
onehundred80
12-27-2015 05:03 PM
csteve0355
11-18-2015 08:35 AM
Quick Reply: What are the multi star bolts used on rear suspension
