N/A coupe and roadster suspension the same?
Old 01-18-2016, 05:56 PM
GTR DRAGON's Avatar
Default N/A coupe and roadster suspension the same?
Quick question guys are the suspension components the same for the N/A coupe and roadster the same? Or are they different like the srt6 roadster and coupe? Also are the N/A coupe and roadster front fenders the same?
Also if any of you guys have these parts local to Southern California closer to the LA area, I would love to pick them up 😊
Old 01-19-2016, 04:17 PM
Default Re: N/A coupe and roadster suspension the same?
I would hazard a guess that they are, look here and see the numbers against the various models in the parts list for your year of car.
Old 01-19-2016, 04:47 PM
GTR DRAGON's Avatar
Thank you Onehundred80, do any of you other guys, have any idea?
Old 01-19-2016, 07:06 PM
read this for your answers
https://www.crossfireforum.org/forum...crossfire.html
Old 01-19-2016, 07:08 PM
velociabstract's Avatar
The suspensions are the same. The spring rates are different. I don't know if the shocks are identical.
Les
Old 01-19-2016, 08:17 PM
Travish's Avatar
The roadsters have 2 extra braces underneath.
Old 01-19-2016, 09:20 PM
+fireamx's Avatar
The spring rates are only different between the SRT's vs the NA cars, Correct? I mean there is no difference in the spring rates of the NA coupes vs the NA roadsters, right?
Old 01-20-2016, 12:53 AM
JHM2K's Avatar
Based on the master parts breakdown for the Limited/Base Crossfire, the springs should be the same.
The rear spring only has one part number listed, 05127493AA
Front is the same situation -- one part number, 05102297AA
If there were different rates, there would be two part numbers per end (or at the very least, in the rear).
SRT-6 springs are different, as they are much stiffer. Same goes for the sway bars -- they will swap from one platform to the other, but they are a bit thicker on the SRT-6.
Aside from the springs and sway bars, the suspensions are the same.
Hope this helps.
djohn14296
03-28-2016 07:52 AM
crossfiremaniac
03-18-2016 09:05 AM
helosixx
01-17-2016 10:22 AM
mr.peebody_2011
01-05-2016 09:21 AM
BisB
12-31-2015 10:41 AM
Quick Reply: N/A coupe and roadster suspension the same?
