Are wheels from an SRT6 the same for coupes and roadsters?
I own a 2005 SRT6 roadster. One of my rear wheels is cracked. Are there differences between the original wheels on a coupe vs. a roadster? What should I expect to pay for wheel? Any recommendations where to find one?
Thank you!
Thank you!
Your rim is bent causing the stress crack. Mine looked exactly like that. I had it straightened and repaired for $75. Been fine ever since. Find a reputable shop in your area.
James
James
Coupe and Convertible wheels are the same.
I've had that exact crack repaired on a Limited coupe rear wheel, a very typical issue with any wide wheel in an environment that has potholes, like Michigan, and I'm assuming, NJ.
I've had to get wheels repaired on every car I've owned, Google wheel repair in you area.
I use the below, there should be something like it in your area.
Welcome to Weldcraft Wheels | Weldcraft Wheels
UrbanE
Mar 14, 2016 11:01 PM
