Hubcentric rings.
I put this on a 2005 NA front hub they are the MB spacers and are hub centric, not sure if the SRT hub is the same. Stock bolts are 40mm you will need longer bolts if you add a spacer, just add the spacer width to 40mm for the right size or a plus 5mm and they will stick out about 3mm on the inside of the hub.
Dan
Dan
I do not know how long the bolts would have to protrude from the hub to do damage but I am sure that info is on here somewhere.
40 plus spacer thickness seems a wise length.
So if I decide to go with 15mm spacers using the stock wheels, what do I need to know to prevent the grease cap fit issue on the fronts? Also I would assume 55mm ball shank lug bolts.
Thanks, James
Thanks, James
The distance to the step inside of the spacer must be a tad more than the outside of the grease cap to the hub face.
The 55mm length is correct.
There is a difference between the SRT and NA front hubs, so you must make sure you state that the AMG front spacers for the SRT. My NA with the 10mm hub centric did fine, but I ordered the same one for the SRT and it does not fit, EZAccessory is sending the one for a SRT/ AMG and I should get it this week will post photos.
what car are you putting these on?
Dan
Dan
How do I know that measurement before buying online?
pholmes237@yahoo.com
Jun 10, 2018 09:16 AM
rcompart
May 13, 2010 04:39 PM
