Quick tire question
Old Oct 3, 2019 | 11:47 AM
  #41 (permalink)
g wheels's Avatar
Default Re: Quick tire question
Originally Posted by Toolman
I can absolutely confirm, because I've done it, that the Schrader 20028 sensors can be learned by the car using a relearn magnet and the Chrysler DRBII for 2004 to 2006 cars, or the Chrysler Starscan for 2007 to 2008. It takes just a couple of minutes. You enter the relearn program and it prompts you to go around the car placing the magnet on each sensor starting with the from left driver side, it beeps prompting you to go to the next sensor. and stopping at the left rear driver side.
THANK YOU!
You are likely the person I believed when deciding to replace the dead sensors. I now know to ask if the service department owns and operates a DRBII tool. I assume there is also a DRBIII as well. If they tell me they only have the Starscan then I'll know to move on. At least I won't sound totally ignorant should I decide to have these sensors relearned.
Old Oct 3, 2019 | 11:52 AM
  #42 (permalink)
Toolman's Avatar
Originally Posted by g wheels
THANK YOU!
Sorry that was a typo I will fix. It's a DRBIII.
Old Oct 3, 2019 | 12:01 PM
  #43 (permalink)
g wheels's Avatar
Thanks! for adding the pictures as well. I'll try to print your reply and carry it with me.
Old Oct 3, 2019 | 12:28 PM
  #44 (permalink)
Toolman's Avatar
Glad to help.
Now the current diagnostic scanner system they use is called the wiTECH Micropod II. That application has a special enhanced emulator option for the DRBIII because that scanner is no longer supported but some dealers still have it. What I read before about the enhanced emulator program was it was only enabled by special request. The video link below from the FCA wiTECH video channel below seems to indicate it should be included but only works with an earlier version (non wireless) of the wiTECH Micropod II software.
Old Oct 16, 2020 | 03:18 AM
  #45 (permalink)
Brian P's Avatar
Default Re: Quick tire & TPMS question
I’m going to replace my front tires next week, one finally shed a steel belt. From rereading this post, it sounds like my best (cheapest) option for getting the TPMS working again is to have Discount Tire install the Schrader Universal sensor #33700, assuming that they have them. I have one year old sensors in the back tires with sensors that have never worked. Assuming that they are universal, should they be able to reset them all? Do I need them to get their codes first? Why does this have to be such a pain? 😄🤪
Old Oct 16, 2020 | 10:38 AM
  #46 (permalink)
Joe_Lukeman's Avatar
Originally Posted by zip439
The rubber compound in "summer" tires will not withstand your winters in Knoxville. They simple are not designed to take temperatures in the 30s F.
You need two sets of tires if you must run "summer" tires. and the summer tires must be stored over the winter in a heated space. A cold garage just won't cut it.
Try reading this; SRT tires
I have summer tires on my car because I store the car in an unheated garage from late fall to early spring. I have not noticed any difference after storing the summer tires in cold NH weather. What should I be looking for? Why should you not store the tires in cold weather?
Old Oct 16, 2020 | 01:54 PM
  #47 (permalink)
He is talking about temperatures in the 30’s and I cannot see what the problem is at all. My tires have been stored at those temperatures for nine years and trouble free.
I would not want to drive them in those temperatures though as they lose grip in the lower temperatures.
Old Oct 17, 2020 | 08:17 AM
  #48 (permalink)
zip439's Avatar
He is talking about temperatures in the 30’s and I cannot see what the problem is at all. My tires have been stored at those temperatures for nine years and troubles.
From what I have learned of todays new summer tires it is okay to store most summer tires in cold temps, so long as they are warmed slowly, naturally back to above 40 before use. The rubber compounds can take the swing in temp and come back to their designed spec. How many times this can occur without some degrading I do not know. You loose performance/grip with most summer tire compounds when temps start getting below 40F.
Old Oct 17, 2020 | 08:38 AM
  #49 (permalink)
At 40F they are not safe, poor grip means poor braking and spinning tires. Below 50F the tires I have start to get dodgy, the tires need to warm up and shortish trips at urban speeds do not get the job done as cold road surfaces keep the rubber temp down.
Old Oct 17, 2020 | 09:21 AM
  #50 (permalink)
zip439's Avatar
Total agree. I think tires made today have different compounds than those you have on your car. Your older tires may also be showing a resultant loose of performance because of the many warm cold cycles they have been through, and the accumulated mileage to the structure and tread grip. Thing is not only summer tire rubber compounds have changed over the past decade, so also has the all season. If I lived in an area with consistent temps below 45 for months during the winter and did not want to have two sets of rims/tires I would only run all season tires on the road.
Many of the top end tire manufactures "secrets" to the cutting edge compounds have been found by most manufactures. As time has passed the (some consolidation in the industry also contributes) tire compounds between manufactures has become less differentiated. Tread patterns and the internal structure is another story. Road conditions are so very important; If it is wet SLOW down and the public roads are no place to be pushing performance anyways.
boucherh
Mar 31, 2011 09:43 AM
nox1s
Jul 8, 2009 02:25 PM
stoy848
Jul 7, 2007 03:40 PM
RGvivace
May 25, 2006 11:50 PM
themann42
Apr 15, 2006 03:08 AM
