rapid rear tire deflation
Old Apr 25, 2020 | 08:52 AM
Distiller's Avatar
Default rapid rear tire deflation
Has anyone else experienced rear tires suddenly going flat? This had happened twice, once on each side, very weird. Reinflate with a portable air pump and everything seems normal again.
Old Apr 25, 2020 | 09:44 AM
Toolman's Avatar
Default Re: rapid rear tire deflation
Some of the standard Crossfire wheels have been known to crack. I would remove the wheel/tire from the car and spray soapy water everywhere to see bubbles to find the leak. Better yet, if you can find a container large enough to at least submerge a third or more of the tire and wheel into water will work even better. A bath tub would work for that, but make sure you protect the bottom and sides as the tire will mark it up and be hard to remove. Besides the cracks, which are rare, it could be the tire bead around the wheel is corroded, the valve stem is cracked, the valve itself could be leaking, and of course punctures in the tires.
Old Apr 25, 2020 | 10:18 AM
By any chance do you park outside? You may be getting pranked?
Old Apr 25, 2020 | 10:19 AM
Yes, the valve stem sticks open and within an hour or so the tire is flat,, when u refill it and the tire stays up the valve stem seated,,, always after filling a tire put a little spit end of the valve steam,,if it bubbles reseat it by useing the inflator nozzle . jim
Old Apr 25, 2020 | 11:16 AM
Distiller's Avatar
It does not appear to be a slow leak, but I'll check the tire, wheel & valve stem for leaks.
Pressures seem to be stable then all of a sudden flat, so yes it could be a person.
Of course the stock tire pressure monitoring light is on all the time so it's useless.
Thanks for the input!
Old Apr 25, 2020 | 11:30 AM
also move the valve stem side to side to make sure it is not broken where it mounts to the rim
Old Apr 25, 2020 | 12:56 PM
If it is someone pranking you, it reminds me of wayyyyy back (like 4-5 decades) where kids would place a very small pebble in the cap on the valve stem. After checking/filling the tire the victim would screw the cap on and a slow leak would leave the guy stranded somewhere until the spare is mounted. Unfortunately our cars don't come with a spare... Catch em and there usually isn't anything you can do unless no one see's you
Old Jul 6, 2022 | 01:00 PM
I had a front tire on my 2006 F-150 that had this failure. Tire went flat as a pancake! Replaced the tire when I got the valve stem replaced.
Old Jul 15, 2022 | 02:39 PM
Distiller's Avatar
Turns out one of the rims was cracked which explains most of the incidents. Recently installed new tires and have had no issues since that time.
Old Jul 15, 2022 | 10:53 PM
I would suspect it depended how the wheel was positioned when parked.
Old Jul 16, 2022 | 10:19 AM
zip439's Avatar
Distiller, Did you repair or replace the cracked rim?
Old Mar 24, 2025 | 07:00 PM
Distiller's Avatar
Replaced it with a used rim found on Ebay.
FIXRE
Jul 9, 2015 09:16 PM
JHM2K
Aug 19, 2011 02:29 PM
blacklimitedcoupe
Jul 31, 2010 04:05 PM
Cobra953
Dec 22, 2009 04:50 PM
jp
Sep 11, 2004 05:43 PM
