Tpms
Old Jul 17, 2020 | 01:54 PM
Harvdog's Avatar
Default Tpms
I just replaced the TRMs on all four wheels but the low tire pressure light will not go out. Any advice on how to reset the light? Thanks
Old Jul 17, 2020 | 04:32 PM
Default re: TPMS
Welcome, a book could be written on this subject using the info about this issue on this forum.
What sensor brand did you use ? That is the first thing we need to know.
Old Jul 19, 2020 | 07:46 PM
KDW4Him's Avatar
Default re: TPMS
Ditto 180 and has the light ever been out?
Old Sep 20, 2020 | 09:26 PM
topless SRT's Avatar
Default re: TPMS
I just had my sensors replaced on my '05 SRT. Same problem. They used REDI-sensor 433Mhz part # se10004A.
Old Jan 9, 2021 | 09:16 PM
ZX2 Nick's Avatar
Default re: TPMS
There's only about a thousand other threads on here asking the same question (that are also full of answers) that you could find.
Your situation is by no means unique to you or the car.
Old Jan 9, 2021 | 09:24 PM
Default re: TPMS
From Clint, one of our members who served as an engineer at Chrysler during the days of the CRossfire:
The big trick is getting a Crossfire to "relearn" new sensor IDs when batteries in the old sensors die. Seems many are lasting 10 years or so, but now that is catching even the newest Crossfire cars. The sensors themselves are not all that special, the same ones were used in Chrysler minivans, in Vipers, and a few other cars. Sensors from Mopar (made by Schrader) will work, direct from Schrader, and I expect many other aftermarket sensors will work - IF you get the car to recognize them.
That is where many tire shops and even Chrysler dealerships will mess up. Most Chrysler cars after Crossfire build time have systems in the car which will automatically recognize that new wheel pressure sensors have been installed, and learn the IDs of the new sensors - just by driving the car for a few minutes (to get the sensors broadcasting their radio signals). Crossfire cars do NOT have the additional antennas, etc. to do this. But lazy or hurried or uniformed techs will assume a Chrysler Crossfire will just learn new sensor IDs without them doing anything but physically installing the sensors in the wheel.
OTHER trick is getting the car into sensor "relearn" mode. This requires the DRB III dealership diagnostic computer tool -- which was obsolete after 2007 for Chrysler dealerships. And to work with Crossfires (or Sprinter vans) needed an additional Multiplexer cable, and Crossfire software card. Which some dealerships never bought, or if bought in 2004, have been lost since. BUT: several indicators say that current Chrysler dealership diagnostic equipment SHOULD have a DRB III Enhanced Emulator function available! So if you can find a Chrysler dealership game to learn something new about their equipment, they CAN do the TPMS sensor relearn on a Crossfire!
EASIER CHEAPER WAY: Find a tire store which can and will CLONE the old working sensor IDs into new sensors. This is by far the fastest easiest, one-stop approach. As long as they can read the old sensor IDs, new sensors can be set to use the same IDs, So no car-side "relearn" necessary!
Attached is a PDF he wrote.
File Type: pdf
Old May 20, 2021 | 08:35 PM
phil alvirez's Avatar
Default Re: Tpms
https://www.banggood.com/IMars-T240-...v&SSAID=389818
at a fraction of the cost and way easier to install. i have them and work great. i hope this helps.
bflinn
Oct 31, 2021 11:17 PM
DanielNTX
Aug 31, 2007 09:30 PM
crossfireGal
Oct 11, 2006 10:30 PM
Copernicus
Jun 19, 2006 01:44 AM
vet4scuba
Oct 27, 2005 07:11 AM
