Replacement Front Brake Suggestions
Hi Everyone, My front brake wear indicator light is on, and would like some suggestions on the right parts to order. I am going to use DT out of Fort Lauderdale as recommended on this board. Should I let them get the parts, or should I order a specific type and supply the parts to DT? Thoughts? Thanks so much. Jody
on
Re: Replacement Front Brake Suggestions
I believe this can be easily done DIY. Not hard at all and a lot of information found here. In fact the rear is even easier! I used Centric Posi-Quiet dustless ceramics all around. Hard to mess up a simple brake pad swap. Good luck, whatever you choose.
Centric Posi-Quiet Ceramic on both my cars. Check around for best price.
For Chrysler Crossfire 04-08 Centric Posi Quiet Ceramic Front Disc Brake Pads | eBay
soulintent
03-20-2013 03:15 PM
BoilerUpXFire
09-27-2009 05:47 PM
