Clint on TPMS Issues
2 Attachment(s)
These questions keep coming up:
What sensors work with our cars? How do I get the tire light to go out? Why can't my tire dealer handle this - they said they could, but I"m out $1000 and the light is still on..... Clint (formerly of Chrysler, he was on the engineering team(s) that worked on various safety aspects of the Crossfire and other products at the time) provides the following. Please download the attached files. |
Re: Clint on TPMS Issues
I got my SRT in 2011 from the US and failed to pass the required safety inspection because of poor treads on the rear wheels, to speed up the process I borrowed two rear wheels from another SRT owner. It passed the test just fine, later I realized that the wheels were set to different TPMS codes to the tire that was on there originally.
My question is why did it not set the red light? I did not disable the TPMS module. |
perhaps the loaner wheels/tires were not driven on long/far enough to trigger the light?
(Post 945408)
I contacted ATEQ TMPS TOOLS USA regarding their ATEQ Schrader EZ Sensor TPMS Diagnostic Relearn Programming Tool Starter Kit S41 and this was their response:
From: emorin@ateqtpmsusa.com Sent: July 28, 2021 8:44 AM To: bluecoupe Cc: support@ateqtpmsusa.com Subject: FW: Contact Us en-us Good morning Mr. Collins, yes the S41 will allow you to program an EZ sensor and perform a relearn on a 2005 Chrysler Crossfire. From: Grant Barnes <gbarnes@ateqtpmsusa.com> Sent: July 28, 2021 8:32 AM To: ATEQ TPMS Tools - USA <help@supporttpms.com> Subject: Fwd: Contact Us en-us OUR ADDRESS HAS CHANGED! ATEQ TPMS Tools, LC 41144 Vincenti Ct., Novi, MI 48375 c.248-872-4429 | o. 734-838-6119 ext. 113 ateq-tpms.com Subject ATEQ Schrader EZ Sensor TPMS Diagnostic Relearn Programming Tool Starter Kit S41 Message Hello, will the ATEQ Schrader EZ Sensor TPMS Diagnostic Relearn Programming Tool Starter Kit S41 work with my 2005 Chrysler Crossfire SRT6 ? If not, which Ateq TPMS tool will ? Thanks Can anyone on this forum confirm this works with our Crossfires? https://www.tpms.com/ATEQ-Schrader-E...p/s41kit10.htm |
(Post 958953)
(Post 945408)
Originally Posted by KDW4Him
(Post 958975)
I suspect the previous owner did. This mod is all over the forum and Fakebook.
The light came on a few times over the years when the pressure was a little low and it became cold. This spring the light came on with the correct pressure in each tire and I personally disconnected the TPMS module as per the thread by Rudy which by now is all over this forum and FakeBook as you say. |
Ronman, I’m guessing you don’t don’t have any experience using this tool. Maybe someone who has will provide an answer.
(Post 958982)
Originally Posted by Ronman
(Post 958986)
I bet the person who answered your email has zero experience also. There is nobody that is going to emulate the special software they made for the Crossfire TPMS. Nobody even makes a scan tool that properly reads all the modules for the Crossfire. The only way is to clone your existing sensors or use a DRB 3/emulator plain and simple.
From: emorin@ateqtpmsusa.com Sent: August 2, 2021 8:30 AM To: bluecoupe Subject: FW: Contact Us en-us Good morning Mr. Collins. The dealers are correct that an OE tool is required to perform the relearn on this vehicle (pair new sensor IDs with the vehicle’s ECU). As far as the programing of sensors is concerned the S41 can both create (assign a unique ID and protocol) and copy sensors. |
(Post 959165)
Ronman you win the bet! I contacted Ateq again quoting your response and received the following reply:
I'm experiencing an issue with my TPMS. light on, replaced all four 3 years ago. All tire pressures are at 35. Can the TPMS tool that the "stealerships" have for programming our system be used to detect a weak or failing tire sensor? This is on the blk SRT.
https://www.crossfireforum.org/forum...tml#post957514
The link above I feel is decently informative. To my knowledge your local tire store can tell if a sensor is transmitting. If it is not is when the options of Schrader or Autel come into play. If it is OEM you seek I have that listed as well. |
I disabled the light and used the tire stem monitors ( red-yello green ) that show low pressure, it gets checked often enough that this works for me. Batteries and sensors are an unwanted expense. On my RAM I had the aluminum stems rot out-leak and used standard rubber stems, solving that issue. I work on my cars and years ago this was not a problem, now a costly dealer feature that has minimal value versus the cost. Woody
Originally Posted by waldig
(Post 959300)
:) Ditto on the bypass! :) . |
