Spare wheel/tire
Old Jan 27, 2021 | 12:42 PM
DirtyDen8810's Avatar
Default Spare wheel/tire
Do you fellows know if a space saver spare wheel/tire from a R-170 or SLK will fit our 04 coups? I would buy one if yes..
Old Jan 27, 2021 | 01:25 PM
Default Re: Spare wheel/tire
Some info here.
Mercedes Space Saver Spare Tire - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Jan 27, 2021 | 02:21 PM
Thank You to the 'Z" man. I bought it. Your advice is great.
Old Feb 14, 2021 | 01:49 PM
Duke11's Avatar
DirtyDen,
Are you able to stand the spare tire vertically in the trunk, or do you have to lay it flat?
Thanks, Duke
Old Feb 14, 2021 | 06:13 PM
In the coupe, you can lay it flat.
Old Feb 15, 2021 | 09:11 AM
Just as the Z man says, I shall lay it flat over to the right side. Since it is the expandable type, there is plenty of room on the floor. The coupe is in winter storage at this time. When I get it out and set it up I will send photos. Seems to me that the air compressor is quite faint-hearted. I shall get a more substantial pump. I have the 12mm X 1 inch wheel lug bolts with 17mm hex heads so as to fit the same lug wrench. The pump will draw up to 30 amps so it will not be used at the interior power outlet. It has battery clamps for under the hood connection. I have replaced the sealant container with a deluxe tire repair kit.
Old Feb 15, 2021 | 10:17 AM
In a crash it can come over the seat and hit you in the back of your head which may be planted in the air bag.
It must be tied down somehow.
Old Feb 15, 2021 | 01:31 PM
Your right about that. I shall move it to the roof top. ,,,,,,,Just jiving you. .... If I bolt it to the floor, I will cut the trunk cover into two pieces so as to be able to lift the left side with spare in place. Tues.Feb 16 2021' An edit. If i need to mount my spare tire then I should also bolt down any luggage that is put into the hatch area. . Where does it all end. I ain't going to mount any thing. Screw it.
blackpepper
Jun 3, 2014 04:19 PM
bkrdoug
Dec 28, 2012 08:44 AM
Mr. Burns
Apr 29, 2009 07:34 PM
danewby
Sep 1, 2008 01:03 PM
steve1173
Oct 23, 2007 10:25 PM
