Rear sway bar bushing
I saw a post last month and now can't find it. 2005 roadster rear sway bar bushing. Someone thought this part was identical for a Mercedes slk 320(not sure my memory is right on exact model). Impossible to order new through any outlet I've found. Any thoughts?
type one the the following into google or bing. You do not specify what model crossfire you have
2004 mercedes slk320 rear sway bar bushings
2004 mercedes slk32 amg rear sway bar bushings
The sway bar for the Crossfire is bigger than the one for the slk 320 so the bushings are not the same.
Is yours in really bad shape or did the sway bar brackets break?
The bracket that holds the bushing? Or the bracket that is welded to the body/underside of car?
dayjor
Jun 6, 2014 11:20 PM
skrzypekusmc
Apr 4, 2008 05:26 PM
