Soft ride?
Old Sep 2, 2005 | 06:54 PM
Cali Crossfire's Avatar
Default Soft ride?
Any suggestions on replacement tires that will give a softer ride? I love my XF but its killing my bad back.
Old Sep 2, 2005 | 08:20 PM
Aero Blue's Avatar
Default Re: Soft ride?
The Continentals have gotta ride better than the Michelins, seeing that one is pure performance. The other suggestion is to go with a taller profile giving you a bit more "cushion". I've seen 235's on the front and 265's on the rear, but that's about it. You might have to sell the car because it is a sports/tourer after all. BTW, your car is the nicest lookin' one here, was it repainted and what type of wax do you use, we gotta know!
Old Sep 3, 2005 | 09:17 AM
andrew's Avatar
-C-I-C-C-I Associate Member
i would lower the tire pressure a tad. but not under inflating them.
Old Sep 3, 2005 | 02:27 PM
Thanks, Roger
I want to try a few things before I give up. I use Meguiars mirror glaze #2 fine cut cleaner to remove spots and swirls first, then Meguiars mirror glaze professional hi-tech yellow wax #26. Its Brazilian number 1 carnauba wax.
Old Sep 3, 2005 | 02:29 PM
I will give that a try, Thanks.
Old Sep 3, 2005 | 04:53 PM
Dan Root's Avatar
Banned
Try a better set of seats! Like 500 SL.
Old Sep 3, 2005 | 05:43 PM
HDDP's Avatar
Another brilliant suggestion from DAN... Try the Toyo S1-R, sidewalls are way too soft for the track, but are pretty good for daily driving... I don't think they will be softer than the OEM tires, but if you're experiencing a hard drive from the OEM suspension (WHICH IS SOFTER THAN JELLO) maybe you got the wrong car ! Perhaps you should think about a cruising sedan...
Kodebuster
Nov 5, 2020 04:06 PM
brandoni
Sep 30, 2015 07:48 PM
atdavis2
Sep 21, 2015 01:25 PM
Bill F
South Forum
Sep 11, 2015 02:29 PM
ttosh
Jul 31, 2015 11:06 AM
