Is a +40 offset okay to run
Old Feb 5, 2024 | 10:35 PM
EvanR's Avatar
Default Is a +40 offset okay to run
I'm looking at picking up a set of 18x8.5 and 18x10s running 255 40 18 and 285 35 18 I'm just curious on if the off set is too much should I run spacers and if 255s will fit up front
Old Feb 6, 2024 | 09:03 AM
NeedsWings's Avatar
Default Re: Is a +40 offset okay to run
+40 will require a space in front, 255 wire front tire will require an even larger spacer
Old Feb 6, 2024 | 10:37 AM
EvanR's Avatar
Thank you for that I just got to work and started looking for tires and due the the massive price difference and your input I'm gonna go with 245 front and 275 in the rear same everything else and definitely gunna pick up some spacers
cjw
Nov 18, 2011 06:02 AM
kolevski
Jan 5, 2011 06:08 PM
velociabstract
Jan 4, 2011 12:40 PM
ryan48
Nov 3, 2009 02:41 PM
Wedge
Racing
Mar 13, 2009 09:34 PM
