Tire Rotation
It says on the sidewall of the tire with an arrow if they are "Directional"
If they are they can not be rotated
Here's a picture from a post I did a while ago.
I didn't know they use bolts interesting thanks for the tip
another question, just had new tires installed on SE wheels (similar to SRT wheels) and they bent one of the lug caps. So I was looking, how do you remove those caps?
If you have the original caps, if you look closely, you will see a mall slot to put a screwdriver in and carefully pop it loose. when reinstalling, line the slot in the cap up with the wheel.
