One brake pad in the rear wheel was wearing out more
Old Feb 21, 2026 | 04:03 AM
Myopic's Avatar
Default One brake pad in the rear wheel was wearing out more
In my car, the mechanic noticed that one brake pad on the left rear wheel was wearing more than the others.
So, the entire brake caliper, rear brake pads, and rear brake hoses were replaced, along with the handbrake linkage.
Of course, the entire brake fluid system was also replaced.
Since it had been a year since the last oil change, the engine oil and oil filter were also replaced.
The air filters and cabin air filter were also replaced – I had hoped they would only need to be replaced every two years, but unfortunately, upon removing them, they were terribly dirty.
Since the multi-ribbed belt was too loose, it was replaced with a new one, as well as the belt tensioner and idler pulley.
These car repairs, i.e. parts and labor, cost me $670.
Old Feb 21, 2026 | 09:14 AM
Default Re: One brake pad in the rear wheel was wearing out more
Looks like you were way overdue for an oil change.
Old Feb 21, 2026 | 09:17 AM
Myopic's Avatar
@ZERACER Why this conclusion?
I changed the engine oil on February 13, 2024, and exactly one year later, on February 13, 2025.
Should the oil be changed more than once a year?
Old Feb 21, 2026 | 09:47 AM
No, I change mine every 5k-7K miles. It just looked black. Mine is always dark amber. How many miles on your Crossfire and do you use synthetic 5W40 oil?
Old Feb 21, 2026 | 09:51 AM
Myopic's Avatar
@ZERACER I've driven 13,000 km in a year.
Yes, I use 5W40 engine oil.
Old Feb 21, 2026 | 09:54 AM
Everything should be fine. Happy motoring.
Old Feb 21, 2026 | 01:33 PM
Myopic's Avatar
@ZERACER Thank you for bringing this to my attention. Regards.
Old May 29, 2026 | 01:52 PM
jovoke's Avatar
The air filters and the cabin air filter were also replaced – I had hoped they would only need to be replaced every two years, like checking a bmw breakers yard for used parts, but unfortunately, upon removal, they were terribly dirty.
Since the multi-ribbed belt was too loose, it was replaced with a new one, along with the belt tensioner and idler pulley.
$670 for all of that work is very cheap. That’s a lot of labor and multiple systems (brakes, fluids, filters, and belt system). Normally it would cost noticeably more in most shops.
Old May 29, 2026 | 02:07 PM
Myopic's Avatar
@jovoke thanks for the feedback 🙂
Old Yesterday | 10:48 AM
About the brake wear, lube the sliding rods/pins, this way the calipers 'float' and seek their own center. IF the parking brake is wearing uneven, make sure there is no parts hanging up & the brake is adjusted properly. Great that you did the services, looks like it was ignored for far too long!
xintersecty
18
May 2, 2026 07:51 PM
abergero
Nov 14, 2022 11:07 AM
hustler316
Aug 11, 2013 04:17 PM
grip grip
Jul 4, 2013 09:12 PM
woody
53
May 4, 2006 10:01 PM
