Can I use 35 mm offset on a 17 x 7 inch rim? (for snow tires)
Old Nov 23, 2005 | 10:20 PM
JBsZ06's Avatar
Default Can I use 35 mm offset on a 17 x 7 inch rim? (for snow tires)
Mercedes SLK Rims are 37 mm offset.
These rims I just bid on say they are good for Mercedes benz slk's but the offset is 35 mm, not 37 mm?
I'm in big trouble here guys and could use some insight...
Will 35 mm's instead of 37 mm offset work ok on the crossfire? If they work on an slk?
Thanks in advance...(doing all this for a 77 year old family friend who owns the crossfire and now wants snow tires and rims...) I'm working way too hard but just want to help.
I don't have any other place to turn for advice here guys so please accept my apologies for all these questions...
JB
Old Nov 23, 2005 | 10:36 PM
+fireamx's Avatar
Default Re: Can I use 35 mm offset on a 17 x 7 inch rim? (for snow tires)
JBsZ06, I don't think the slightly larger offset should make a difference since the rim is only 7" wide, and you will be using a narrower snow tire. The current rear wheel on your car is 9" wide, so that would put the inside of your tire alot closer to the inner fender than a 7" wide rim would. I hope this answers your question...Mike
Old Nov 23, 2005 | 11:21 PM
JBsZ06's Avatar
Thanks Mike.
So it sounds like 35 mm offsets should work with the crossfire?
No problem with brake caliber clearances etc?
Like I said..I've read that this snow tire mod works with slk rims from this great site....but winters coming and no slk rims available. Then I spotted this aftermarket rim on ebay that says it fits SLK's...
So I bid...then I realize the offset is 35 not 37...
I sure hope it fits.
Thanks
Old Nov 24, 2005 | 12:16 AM
+fireamx's Avatar
As far as I know, the brakes on the XF are supposed to be exactly the same units that are on the SLKs, so if the wheels that you're bidding on came off an SLK, I would think everything should be OK.
Old Nov 24, 2005 | 06:56 AM
bobs's Avatar
I second that. They are made by Ate and have the MB 3-pointed star cast into them so unless DC did something funky with the geometry (which I doubt) those wheels should fit fine. If they do bump into something you could always add spacers to compensate for the narrower wheel.
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
Freezer
Aug 6, 2015 07:24 PM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
