Rear Rotor Removal !!!! HELP
Old Jan 7, 2006 | 07:10 AM
HDDP's Avatar
Default Rear Rotor Removal !!!! HELP
I'm having problems removing the rear rotors... The step-by-step procedure from the manual does not work... There seems to be a bit of an issue that DC left out... It has a 12 point star nut that has been sealed to the axel by crimping a divot into the end of the nut, onto the shaft...
The manual describes a very basic process, which I followed to the T... But this darn thing won't budge... Any help from someone would be appreciated... Because I can't figure this one out...
Old Jan 7, 2006 | 01:19 PM
Cyril Baldwin's Avatar
Default Re: Rear Rotor Removal !!!! HELP
Do you have a wheel spacer on it? Sometimes I noticed that the wheel spacers seat crooked in the hub, you might try to use a rubberized hammer to loosen it up.
Old Jan 7, 2006 | 01:35 PM
HDDP's Avatar
The spacers have only been there for a couple of weeks with very few miles, so I don't think that's it... I WD40'd the heck out of it... The manual is pretty specific, remove caliper, remove set screw, remove rotor... Yet, neither side will budge even with a bit of tapping. Even though the manual doesn't mention it, it looks like you have to remove the hub nut, but it is forged onto the axel with a divot.
Have you removed the rears ?
The fronts came off easily...
Old Jan 7, 2006 | 07:20 PM
ROY BARBER's Avatar
Talking Re: Rear Rotor Removal !!!! HELP
BET A RICER DON'T HAVE THAT PROBLEM.
Old Jan 7, 2006 | 07:57 PM
HDDP's Avatar
ROY... Stop it with the RICER stuff... LOL, Sounds like you need a good take out order of Chinese food... KUNG POW CROSSFIRE !!!
Old Jan 7, 2006 | 09:41 PM
stryfox's Avatar
I don't have the answer as i have not needed to remove the rotors yet,
I would try the slk forum.
Old Jan 8, 2006 | 01:00 AM
I replaced the front and rear with Brembo's and as far as the manual goes it is really that easy. I did try tapping it when I first installed it.
Old Jan 8, 2006 | 02:05 AM
HDDP's Avatar
Yeah, it turned out that the rotors were seized to the hub... A little persuasion in the form of a mallet helped...
Old Jan 8, 2006 | 02:36 AM
ROY BARBER's Avatar
Angry Re: Rear Rotor Removal !!!! HELP
WELL YOU WILL LEARN ONE OF THESE DAYS, YOU HAVE TO USE A HAMMER ON A GERMAN CAR JUST LIKE A RICER. SEE YOU DID LEARN SOME THING TODAY. THE MORAL BUY A BIG HAMMER BEAT THE H OUT OF IT HELPS RELIVE THE TENSION.
Old Jan 8, 2006 | 07:20 AM
bobs's Avatar
Just remember, if brute force doesn't work it just means you're not using enough of it.
Old Jan 8, 2006 | 08:55 PM
former NXMX5's Avatar
sorry i didn't see this thread earlier; i could have helped. took the rotors off when i painted the calipers, and it is as easy as removing the calipers and the set screws...
too late to help you, but maybe it'll help someone else in the future --
Old Jan 9, 2006 | 12:36 PM
HDDP's Avatar
Originally Posted by former NXMX5
sorry i didnt see this thread earlier; i could have helped. took the rotors off when i painted the calipers, and it is as easy as removing the calipers and the set screws...
too late to help you, but maybe itll help someone else in the future --
Thanks: It turned out my rear rotors were seized on the hub and needed a little persuasion !!!
Old Jan 9, 2006 | 01:49 PM
bobs's Avatar
Glad to hear you got them off. Be sure to let us know how those SRT-6 parts work out. I'm half tempted to do this mod myself....
Old Jan 9, 2006 | 02:23 PM
HDDP's Avatar
BOBS: Will do... as a test, I only ordered the left front SRT6 rotor, caliper, pads, backing plate to see if it will work... The parts should arrive this week...
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
rocketrage
Oct 7, 2015 05:00 PM
tom2112
Jul 28, 2015 08:12 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
