Needswing Oil Catch Tank
Old 12-06-2016, 01:55 PM
ardenian's Avatar
Default Needswing Oil Catch Tank
Hi Guy's < just bought the oil catch tank from Needswing with the front camber bolts and the speed of delivery from the USA to the UK was amazing.
I have a question about the catch tank as I have a UK 6 speed manual N/A and I cannot work out where to put the unit as there is not much space . Anyone sorted this out in the past?
Any help would be appreciated.
cheers, Ian.
Old 12-06-2016, 03:36 PM
harbor's Avatar
Default Re: Needswing Oil Catch Tank
Look at the upper right hand corner of this pic of ala_xfire's engine compartment. Catch can is designed to go just in front of brake fluid master cylinder and bolts on underneath.
http://cimg3.ibsrv.net/gimg/www.cros...91f64a6124.jpg
Old 12-06-2016, 04:07 PM
Except on your car that is on the opposite side.
Old 12-06-2016, 07:19 PM
NeedsWings's Avatar
please send me an email
Old 12-06-2016, 08:28 PM
Administrator / Senior Member
Hmmm......never thought about that
Are the engine compartments reversed on a European right hand steering Crossfire ?
I have ever seen a pic of one of those under the hood or if I did I didn't notice.
Anyone here who can post a pic and clarify this ?
Old 12-06-2016, 10:44 PM
turbomar's Avatar
The brake assy. and fuse box are switched over for the battery and ECU box. Pause at 1:10 for a look:
Old 12-06-2016, 11:08 PM
Thanks for the video clip....I didn't ever think about the difference under the hood on a European model
I captured a screen shot here
Old 12-06-2016, 11:12 PM
Go to the link in my signature, go to the bottom of the list and you will come to the title NeedsWings Documents and find the document on the catch can instal.
It shows the LHD instalation but I am sure you can do something similar.
It is the NeedsWings how to, others have not received instal instructions in the past, whoever packs them is omitting to add the instructions.
Old 12-07-2016, 07:28 PM
daveesrt6's Avatar
Here is my ccan installed.
edit ,see later post
Old 12-08-2016, 10:36 AM
ardenian's Avatar
Hi Guy's, thanks for the replies Rob at Needswing has been on the case and has sorted it out for me. It will be just like daveesrt6's photo's.
Old 11-27-2017, 07:46 PM
Jim Holian's Avatar
Gentlemen = Not to sound ignorant but, what is/does the oil catch can do? Obviously, as it's name implies, it catch's oil, but from where. I just bought my first Crossfire, a 2005 model, so I may have what seems like some silly questions. My theory is "if you don't ask, you'll never know".
I did notice a little oil under my new, to me, Crossfire. Very little, but still there. The man I purchased the car from told me that the dealer slightly overfilled the oil on the last change and that I would notice a "high" indicator on the dash. He told me to just turn the small dial and the indicator would go away. All of this happened on the way home. In the past, I've always worried about a blown seal if the oil level was too high. Does a catch can help in this department, the slight overfill and the spot under the car?
Please bare with me as a new, first time owner. Any information will be greatly appreciated. By the way, my car is a "limited" and has an automatic trans.
Thanks in advance,
Jim
Old 11-27-2017, 08:16 PM
harbor's Avatar
Thanks in advance,
Jim
Oil Catch Cans | Everything you need to know and more!
Old 11-27-2017, 11:17 PM
I read the link. Unfortunately, it didn't tell how often the oil catch can needs emptied. Anyone? Thanks!!
Old 11-27-2017, 11:39 PM
daveesrt6's Avatar
I empty it after every second oil change, thats about 8k miles,
there is not much in it maybe a 1/4 cup but its better there than thru the intake !
Heres a recent pic showing my RHD catch can .
Old 11-27-2017, 11:56 PM
great info!.....thanks!!
Old 11-27-2017, 11:59 PM
daveesrt6's Avatar
oops wrong thread
Old 11-28-2017, 10:44 AM
Jim Holian's Avatar
Harbor - WOW! Very nice article about the catch cans.
Thank you for your input. Now I understand.
Jim
