Relay Control Module
Greetings,
Have a periodic issue with starting my 2005 Coupe and saw a couple Utube videos on the subject indicating that it is due to a faulty part - A1705450005 (according to Chrysler dealer). Chrysler parts dept said it is a Mercedes part and to order from them; Mercedes parts says it is not their part and must be ordered through Chrysler and that they do not service Crossfires or install parts. When the problem occurs the key will turn but that is it. Cooling fan comes on and the dashboard is black with all the warning lights on. Anyone out there had such an issue and is getting an aftermarket part the solution?
Re: Relay Control Module
Greetings,
Read up on these 2 threads they explain a lot. Good Luck to you. Oh and welcome to the forum, remember these cars are essentially '03 '04 SLK 320's R170 chassie. Most if not all chassis ,engine, trans parts are interchangeable. Even a lot of the interior will fit.
https://www.crossfireforum.org/forum...fire+03+slk320
Greetings,
Your problem sounds like the RCM problem. CLICK
The part is the BCM, listed wrongly in this eBay ad as a RCM. CLICK
That is the ever elusive PULSE MODULE !
on
OK, now I am confused. Dave, your saying this part in the auction is the BCM? On multiple ebay auctions it (this part number) comes up as the RCM BUT that thing in no way matches my RCM in my 08. I thought the RCM was the same on all 5 years of our XF's (and the 01-04 SLK320 as a minimum). Can those auctions all be that wrong? I know some pull pictures/descriptions from others auctions but this many?
If it is the BCM, why so few terminals? Is this BCM that complicated inasmuch as it is doing so much work on its data buss?
on
George
( Hi back )
I get to add a new line to my "Dave screwed up journal". That makes 2 in 7 years.
If this is what's happening, it's the RCM. $50 gets it fixed better than new!
Email me at tighed1@hotmail.com for details
One site even identified it as the Multi Media Control module.
I also made a mistake once when I thought I had made a mistake but actually had not.
on
https://www.youtube.com/watch?v=E85akJMdmFo
If this is what's happening, it's the RCM. $27 gets it fixed better than new!
Greetings,
It would be most likely the BEST $27.00 you spent on your XF! The car is at least 12 years old already and the cost is quite outstanding in value!
^^^^^ What he said.
To all of you that have NOT had your RCM overhauled by DJ, YOU ARE DRIVING ON BORROWED TIME with all our cars now over 10 years old.
I've never made a mistake, now that I think back on it. I have had "errors in judgement" though! They crop up all the time! Hah!
Having a "disagreement" with Dave is sorta fun. I just don't take it personal, but I'll stand my ground the same as him on an issue I'm confident about. I acknowledge that he has a tremendous amount of knowledge about the Crossfire & has provided valuable tips on what my problem is and how to solve it. What more could you ask for!
